Skov
oscilloscope schematics
>>That is not true, normally the input impedance of oscilloscopes is 1 MΩ || ~10-100 pF.
I don’t understand what are you talking about.
The question was why the oscilloscope has limitation +-5V for input voltage.
Do you mean that you know the oscilloscope with such limitation and input
impedance >1K ?
There are exist a lot of kinds of oscilloscope in the world.
I know oscilloscopes with 100K,1M. My own oscilloscope has 50 Ohm input impedance.
His bandwidth is 500MHz. The low input impedance allows to decrease the distortion of signal
in communication cable. Usually the wideband oscilloscopes have low input impedance.
See, for example,
As a rule, some probes are added to such oscilloscopes for investigation of high voltage signals.
I think that all DSO are low impedanse oscilloscopes in principle,
becouse the limitation for input voltage of ADC is rather low.
A probe is just incorporated in the scheme of the high input impedance DSO.
impedance >1K ?
See, for example,
