Difference between BSP and device drivers ?
kk2mkk
Member level 2
Hyderabad India
bsp drivers
can any one summarize the difference between BSP and device drivers ?
thanks in advance
kk
bsp driver
look, BSP is the set of your hardware driver. If you have windows mobile or CE already instaled and want to add some new hardware, you don`t need another bsp, but another device driver. When you will compile windows for the very first time, you need a set of drivers of you hardware. Normally, your vendor provides it. Were i clear? good luck!!
Breno
bsp device driver
Actually a collection of hardware(device) drivers is nothing but the BSP(Board Support Package) of the Main Hardware,where the Board(Main Device) is comprised of the included Hardwares(Devices) .
If you are interested to add some other hardware to your main board then you don't need to change the BSP, but you must have to add the Device Drivers of those new Hardwares .
