Difference between 16f877 and 16f877A
mihipihi
Newbie level 1
Newbie level 1
anyone have simple schematic witch elements I must add to microcontroller.
difference between 16f877 and 16f877a
what?????????????????
16f877a ethernet
This has an internal oscillator, so you shouldn't need anything except to pull MCLR high.
16f877 oscillator
hellooooo?????????????
have u seen the datasheet of 16F877 ??
i guess not. because it doesnt have an internal oscillator.
and mihipihi would you plz tell what you want to do because your question is headed in no way. a system based on a 16F877 can be a full blown ethernet server and it can also be a simple LED flasher. so the components that should be connected with it depends on what you want to do
__config 16f877
I'd recommend studying the datasheet:
https://ww1.microchip.com/downloads/en/DeviceDoc/30292c.pdf
The 16F877 has no internal oscillator, so an RC, crystal or resonator and some caps are needed (see datasheet: 12.2 Oscillator Configurations). Don't forget the pullup @ MCLR and an 100nF @ Vdd - that's all.
Btw: 16F877 is obsolete and replaced by 16F877A
Mik
16f877 vs 16f877a
i need help
i went to buy 16f877
but i found 16f877A
i have the programmer of 16F877
but some trusted body tolled me there's difference between the
two controllers
i hope some body find a sol. or a schematic for the 16F877A
thanks
16f877a vs 16f877
hi nami,
the difference between 16f877 and 16f877A as follows (as far as i know) :
i) 16f877A is an improved version of 16f877 with additional built-in comparator function.
ii) programmer that supports 16f877 might not support 16f877A.
iii) different in __CONFIG register bits for 16f877A and 16f877.
the rest are exactly the same. eg. pins compatibility, voltage supply, crystal oscillator frequency and etc.
however, there are slight different in electrical characteristic of these two ICs. but this does not really matter. :)
hope this help u..
regards
16f877a crystal oscillator
It depends on how you define "obsolete". Both parts
are still in full production, and will continue to be so
in the foreseeable future. The 877A has more features
and is a bit cheaper, so I wouldn't use the 877 for a
new project, but it is still freely available.
Nick
