DFT errors when trying to insert scan chain to a design
measure_sco should be the last
has gaom9 take the wrong clk to fix?
Thanks for clearing the clock sets, sunilbudumuru
d.f.t.com
He is mistaken at the flow setup and missedout the scan path declaration. rest every thing is fine with his script.
Sunil Budumuru
dft signals
typical question and perfect answers
DFT error
Hi .. I am facing the same problem with my design... after scan insertion in dft complier, when i am using tetramax for test pattern generation and i run this command run_drc s27_dft.spf, I get
DRC-T> run_drc s27_dft.spf
Begin scan design rules checking...
Begin reading test protocol file s27_dft.spf...
Error: illegal context (measure_sco must be the last event in procedure "shift"). (V8-1)
End parsing STIL file s27_dft.spf with 1 errors.
Error: Design rules checking failed: cannot exit DRC command mode. (M100)
its the same problem you guys were facing .. Please tell the solution.
Thank you
Re: DFT error
Thank you
use the standard template format.Its there in the atpg reference manual.
help for dft scripts for multiple clocks..
hi..
can you please sent me the scripts for multi clocks in the design. my design has 2 clocks. Can you help me to write auto fix dft scripts for the multiple clock design....
