Twafs
That's not a great picture, but it sure looks like you've got the battery connected to the wiper.
See post #11.
No, like the guy below said, the markings on the red board is right, the positioning of the pins dont match with the positioning of the tabs on the pot itself.
The labels on the "pins" that are on the red circuit board are labeled S + - so if those are correct it's hooked up to the battery correctly.
I'd disconnect the potentiometer and check using the "tabs" at the top of the potentiometer and measure the resistance across the outer pair with a multimeter.
Youre right. I have now tested the pot and measured the ohms, and i got 10k from each end of the pot, and the wiper seemed to work like it should, from 0-10k ohms when turning it, with 5k at the middle.
What did you mean when you said the voltmeter range is 2.5-30V? Can it measure below 2.5V? And have you tried using a DVM to verify the readings from your little meter?
It can measure below 2,5V but its only a 2 wire voltmeter, so the voltage measured is also the voltage powering the voltmeter. Could this be the problem? When measuring it the intrument barley moved, so i would guess 50kohm>.
I am currently working on modifying it so that i can supply the voltmeter power from a seperate wire.
It is obvious that the pot is a logarithmic volume control, not a linear pot.
Without a load when it is turned to half then its output voltage is 0.45V to 0.9V. If it is turned down 20% then its output voltage might be 2.5V.
Im not sure that i get you right, but i got 5kohms in the middle position and 10k ohms to the far side.
not only a logarithmic pot but also in linear pot if the potentiometer resistance is high and if the load resistance is low the same non linearity will arise ..... try a pot with lower resistance if your source doesn't support try a voltage regulator (output voltage controllable), if you still thought it was inefficient you can use a switched regulator (If you want linearity)..
View attachment 96571View attachment 96572View attachment 96573
In all the images the pot is in center position according to the load the output voltage varies.....
For better operation the Potentiometer resistance shd be lower than load resistance.....
I have yet to find an easily controllable voltage regulator.
I will look into the switching regulator.
Hi barry!!
sorry to misread you, I was thinking something else.
BTW for Pot based circuit, I think your device will turn up more into a device dependent voltage as well, since your device impedance will matter a lot when you are setting a voltage.
I would still go on with a buck converter, making one is pretty easy, you can just google it and you'll find some really easy solutions. You just need a capacitor, inductor, a mosfet and a comparator. And of-course a pwm signal
The buck converter sounds awfully complicated to build and hard to control when i just want a 0-10v output.
How will a transistor work ?
