Detecting only daylight
We do not know the application it is to be used in, also this level of detection would affect the response at say dusk and dawn and cloudy days etc. but yes if hes ok with some false triggers (ie headlights) or no triggers then dialing the threshold is pretty straight forward.( I think my 1st post was toward this manner)
-Pb
??? its automatic car headlights.... what more do we need to know ??
We dont know if that is the case, he gave an example of of automatic car lights,
like the sensors on the cars for automatic headlight
keyword being like
he simply gave that as a known case that uses daylight detection.
What sensor do I need to detect only daylight like the sensors on the cars for automatic headlight ?
Yes but i want not to detect the artificial light ... only daylight ?
What sensor to use for these purpose then ? More sens to daylight ?
keyword being like
yes i see what you mean. The requirement & objective is not precisely put, and changes as we go. Ok then, i'm out. :smile:
In addition to other sensing, a 24_hour clock can determine daytime making system more precise.
Hello everybody ,
Yes i want to make automatic headlights . I will try with the lux meter to microcontroller . Can someone link a example circuit ?
Thanks
Or idea which sensor to use ..
Ok if you are trying to make automatic headlights, why do you care if you are sensing daylight vs artificial? shouldnt you just be sensing the lack of light? then you set the threshold of a photodiode to be high, over sample it so say the sum of the last 50 results all show a level above the threshold, and turn lights off to reduce chances of artificial light source from triggering. place the diode at the top of the console so it wouldnt be hit by oncoming traffic headlights. (remember when driving its better to have false alarms to trigger headlights on, false offs could be... deadly).
Characteristics of the sensor should not be symmetrical. He must work quickly with the loss of light (for example - poorly lit tunnel) and slowly when the light appears.
Can you tell me example of that sensor ?
Agreed, I mentioned an arbitrary number of 50 samples to turn off, and meant to imply a smaller number to turn on, not 1 because you dont want a road sign block the sensor when driving and turn the lights on, but maybe 5 samples or something.
The first recommendation I gave you is an example of the circuit. photo diode , comparator, and a means to look at some form of running average( a PIC storing the last 50 values as a sum or average would work, or a switch cap integrator would be an analog version.
I'm not sure that the author of the topic enough knowledge to implement the scheme for the PIC. In the analog version, I would suggest two consecutive integrator with a time 0.5s and 30s, two comparators and a state machine for four states. In addition, the temperature drift compensation scheme photodiode because the working temperature range of -20 / +40 ° C.
Give a schematic how to wire a photodiode to op-amp and then to PIC ADC and what to use for temperature compensation ? A diode or thermistor ?
Thanks
Try something like EL7900
Read application notes for it, it is simple.
