Designing with INA3221
engr_joni_ee
Advanced Member level 3
I am working with adding INA3221 in my schematic. I am wondering about the address pin. There is only one address pin Ao. The pin Ao can be attached to GND, VS, SDA, or SCL. Does it means only four devices INA3221 can be attached to I2C bus ?
The slave addresses (7 bits) mentioned in Table 1 in the datasheet has only four different addresses which corresponds to four Ao connection options.
Question: How can we add six INA3221 to I2C ?
Like always ...
You ask a question about a specific device, but don´t give a link to it´s datasheet.
If you don´t want to invest the time.. I don´t either.
From the shown table it seems there can "only" be 4 such devices on the bus. But why "only"? Many I2C devices don´t offer 4 different addresses.
Without having a look into the datasheet: you always have the option to use different I2C busses, or split an I2C bus using an "I2C MUX"
Thanks I will either use I2C Multiplexer or add another I2C bus in the design.
Regarding the value of shunt resistor. I did following calculation.
According to datasheet, the maximum voltage across shunt resistor is +/- 163 mV.
I have 3.6 A max running through the power cables. The supply voltage at the load is 3.3 V.
I found 39 mOhm through hole resistor having power rating 3 W tolerance +/- 5%. I also found SMD with tolerance 1%.
The voltage across shunt resistor will be
V = I x R
V = 3.6 x 39/1000
V = 140 mV
The power dissipation across shunt resistor will be
P = V x I
P = 140/1000 * 3.6
P = 0.5 Watt
What will be the resolution of the current measurement ?
Considering 2 bit noise in 13 bit ADC.
3.6 A / 2048 = 1.75 mA
Is my calculation make sense for 11 bit ADC ?
Link to datasheet INA3221 is
I´m positively surprised. You did some math.
* 39mOhms is correct
* 140mV is correct
Resolution is independent of noise. ADC is 13 bit.
According datasheet the "shunt step size" is 40uV. According Ohm´s law: I = V / R = 40uV / 39mOhm = 1.03 mA step size = resolution.
Errors are:
* ADC_offset (and drift)
* ADC_gain (and drift)
* ADC_noise
* ADC_nonlinearity (INL)
* wiring
* shunt resistor tolerance
* shunt resistor drift
* maybe more
PS:
your link is rather long, with a lot of unnecessary informations.
it could be:
* https://www.ti.com/lit/ds/symlink/ina3221.pdf
* or INA3221 datasheet (using the [Insert Link] button)
.. but well done to link directly to the manufacturer´s homepage.
One last point in this thread is the calculation of junction temperature for INA3221. The datasheet is already shared above.
There are three contributors when it comes to power.
1- Quiescent supply power
2- Input bias power
3- Shunt measurement power
First is the Quiescent supply power. According to datasheet, the Quiescent current is between 350 uA to 450 uA. Let's take the mid value which is
equal to 400 uA.
Supply Quiescent power: IQ x Vs = 400 uA x 5 V = 2 mW
Second is the input bias current.
Input bias current at IN+ = 10 uA
Input bias current at IN- = 10 || 670 μA || kΩ
I am taking 10 uA as input bias current.
The value of shunt resistor is 0.39 mOhm and the shunt resistor voltage is 140 mV. Can I take 70 mV as common mode voltage ? Please comment of the value of common mode voltage (VCM)
Input pin power (for 2 pins): 2 x IN+ x VCM = 2 x 10 uA x 70 mV = 1.4 uW
Thirds is the shunt measurement power.
Vbus measurement power: (VCM/Vbus_Impedance)*VCM = 0.5 W
The total power will be the sum of all three contributions which is almost equal to 0.5 W.
Junction-to-ambient thermal resistance according to section 7.4 of datasheet is 36.5 degC/W
The junction temperature will be equal to ambient temperature (consider 40 degC) + 0.5 W x 36.5 degC/W = 58.25 degC.
Write your reply...
LaTeX Commands Quick-Menu:
