tapu
Full Member level 5
Dear sir I connected mov But same problom observed.(when bell rings Time stops & keypad not working just like controller stops)last digits on lcd shows but clock stops.
#include <REGX55.H>
sbit set=P1^0;
sbit mov=P1^1;
sbit inc=P1^2;
sbit dec=P1^3;
sbit rly=P1^4;
sbit e5=P1^5;//3rd e5
sbit e6=P2^3;//4th e6
sbit buz=P2^1;
sbit e4=P1^7;//1st e4
sbit e3=P1^6;//2nd e3
sbit SDA=P2^6;
sbit SCL=P2^7;
bit d;
unsigned char dec_hex(unsigned char tt)
if(tt>59)
tt+=36;
else if(tt>49)
tt+=30;
else if(tt>39)
tt+=24;
else if(tt>29)
tt+=18;
else if(tt>19)
tt+=12;
else if(tt>9)
tt+=6;
return(tt);
void all_disp();
void time_set();
void alarm_set1();
void alarm_set2();
void alarm_set3();
void alarm_set4();
void alarm_set5();
void alarm_set6();
void alarm_set7();
void alarm_set8();
void alarm_set9();
void alarm_set10();
void alarm_set11();
void alarm_set12();
void alarm_set13();
void alarm_set14();
void alarm_set15();
void alarm_set16();
void alarm_set17();
void alarm_set18();
void set_date();
void buz_on();
void blink();
void no_op();
void alarm_chk1();
void alarm_chk2();
void alarm_bell_HI();
void alarm_bell_LOW();
void display_day();
void puls();
void no_puls();
#define First_Line 0x80
#define Second_Line 0xc0
#define Curser_On 0x0f
#define Curser_Off 0x0c
#define Clear_Display 0x01
#define Data_Port P0
sbit Lcd_rs = P2^0;
//sbit Lcd_rw = P2^1;
sbit Lcd_en = P2^2;
sbit sda_rtc =P2^5;
sbit scl_rtc =P2^4;
/*sbit Lcd_rs = P3^5;
sbit Lcd_rw = P3^6;
sbit Lcd_en = P3^7; */
void Lcd8_Init();
void Lcd8_Command(unsigned char);
void Lcd8_Write(unsigned char,unsigned char);
void Lcd8_Display(unsigned char,const unsigned char*,unsigned int);
void Lcd8_decimal2(unsigned char,unsigned char val);
void Delay(unsigned int);
void del();
void hour_mode();
void Seg8_decimal2(min);
void Led8decimal2(hour);
void EEPROM_WriteByte(unsigned char eeprom_Address, unsigned char eeprom_Data);
unsigned char EEPROM_ReadByte(unsigned char eeprom_Address);
void I2C_Start();
void I2C_Stop(void);
void I2C_Ack();
void I2C_Write(unsigned char dat);
unsigned char I2C_Read();
#define EEPROM_ID 0xa0
void delay_ms(unsigned int ms_count);
void I2C_NoAck();
void I2C_Clock();
void delay_us(unsigned int us_count);
void msdelay(unsigned int value);
void emerg_bell();
#define DS1307_ID 0xD0
#define SEC 0x00
#define MIN 0x01
#define HOUR 0x02
#define DAY 0x03
#define DATE 0x04
#define MONTH 0x05
#define YEAR 0x06
#define TUESDAY 5
#define ctrl 0x07
DS1307_get(unsigned char);
void DS1307_settime(unsigned char, unsigned char, unsigned char);
void DS1307_setdate(unsigned char, unsigned char, unsigned char,unsigned char);
Send2lcd(unsigned char);
void Rtc_Write(unsigned char,unsigned char);
Rtc_Read(unsigned char);
void Rtc_rd_wr_sub();
void Rtc_Init();
void Rtc_Start();
void Rtc_Tx();
void Rtc_Rx();
void Rtc_Stop();
void Rtc_Ack();
void disp();
unsigned int Rtc_add_wr,Rtc_add_rd;
unsigned char d_rtc,datain_rtc,in_rtc,temp_rtc,dat_rtc,flag_rtc;
unsigned char i,j,a[10],cur=0,cur1=0;
unsigned char sec,hour,min,date,day,month,year,sec1,hour1,min1,sec2,hour2,min2,hh,mm,ss,dd,mn,yy,ahour,amin,asec,amin1,ahour1,ahour2,amin2,ahour3,amin3;
unsigned char amin4,ahour4,ahour5,amin5,amin6,ahour6,ahour7,amin7,ahour8,amin8,ahour9,amin9,amin10,ahour10,ahour11,amin11,ahour12,amin12,ahour13,amin13,ahour14,amin14,ahour15,amin15,ahour16,amin16,ahour17,amin17;
unsigned char count[8]={0x82,0x85,0x8a,0x8d,0xc2,0xc5,0xca,0xcd,}; ///0x8a changed
unsigned char count1[6]={0x86,0x89,0xc6,0xc9,0xc3,0xc6}; ///0x8a changed
unsigned char rly_hex(unsigned char tt)
if(tt>59)
tt+=36;
else if(tt>49)
tt+=30;
else if(tt>39)
tt+=24;
else if(tt>29)
tt+=18;
else if(tt>19)
tt+=12;
else if(tt>9)
tt+=6;
return(tt);
void all_disp()
sec = DS1307_get(SEC);
min = DS1307_get(MIN);
hour = DS1307_get(HOUR);
date = DS1307_get(DATE);
day = DS1307_get(DAY);
month = DS1307_get(MONTH);
year = DS1307_get(YEAR);
sec=Send2lcd(sec);
min=Send2lcd(min);
hour=Send2lcd(hour);
day=Send2lcd(day);
date=Send2lcd(date);
year=Send2lcd(year);
month=Send2lcd(month);
//hour_mode();
Lcd8_decimal2(0xc6,hour);
Lcd8_Write(0xc8,'.');
Lcd8_decimal2(0xc9,min);
Lcd8_Write(0xcb,'.');
Lcd8_decimal2(0xcc,sec);
Lcd8_decimal2(0x82,date);
Lcd8_Write(0x84,'-');
Lcd8_decimal2(0x85,month);
Lcd8_Write(0x87,'-');
Lcd8_Display(0x88,"20 ",2);
Lcd8_decimal2(0x8a,year);
//Lcd8_decimal2(0x8d,day);
Seg8_decimal2(min);
Led8decimal2(hour);
void main()
Lcd8_Init();
Lcd8_Display(0x80,"RTC TESTING: ",12);
Delay(65000);
Delay(65000);
Lcd8_Command(0x01);
Rtc_Init();
puls();
//DS1307_setdate(0x04,0x11,0x11);
//DS1307_settime(0x16,0x00,0x00);
while(1)
all_disp();
//disp();
display_day();
if(day==0x06)
alarm_chk2();
else
alarm_chk1();
if(!set)
Delay(65000);
Delay(65000);
alarm_set1();
alarm_set2();
alarm_set3();
alarm_set4();
alarm_set5();
alarm_set6();
alarm_set7();
alarm_set8();
alarm_set9();
alarm_set10();
alarm_set11();
alarm_set12();
alarm_set13();
alarm_set14();
alarm_set15();
alarm_set16();
alarm_set17();
alarm_set18();
time_set();
set_date();
void emerg_bell()
void no_op()
void hour_mode()
if(hour==13)
hour=1;
d=1;
if(hour==14)
hour=2;
if(hour==15)
hour=3;
if(hour==16)
hour=4;
if(hour==17)
hour=5;
if(hour==18)
hour=6;
if(hour==19)
hour=7;
if(hour==20)
hour=8;
if(hour==21)
hour=9;
if(hour==22)
hour=10;
if(hour==23)
hour=11;
if(hour==24)
hour=12;
void puls()
Rtc_Start();
Rtc_Write(0x07,0x10); /* Write date on RAM address 04H */
Rtc_Stop(); /* Stop i2c bus */
void no_puls()
Rtc_Start();
Rtc_Write(0x07,0x00); /* Write date on RAM address 04H */
void display_day()
if(day==0x01)
Lcd8_Display(0xc1,"SUN ",3);
if(day==0x02)
Lcd8_Display(0xc1,"MON ",3);
if(day==0x03)
Lcd8_Display(0xc1,"TUE ",3);
if(day==0x04)
Lcd8_Display(0xc1,"WED ",3);
if(day==0x05)
Lcd8_Display(0xc1,"THU ",3);
if(day==0x06)
Lcd8_Display(0xc1,"FRI ",3);
if(day==0x07)
Lcd8_Display(0xc1,"SAT ",3);
void set_date()
buz_on();
Lcd8_Command(0x01);
all_disp();
cur=0;
while(set)
Lcd8_Command(0x0f);
Lcd8_Command(count[cur]);
if(mov==0)
while(!mov);
cur++;
buz_on();
if(cur==4)
cur=0;
else if(count[cur]==0x82)
if(inc==0)
while(inc==0);
date++;
buz_on();
Lcd8_decimal2(count[cur],date);
if(date>=31)
date=0;
else if(dec==0)
while(!dec);
date--;
buz_on();
if(date==0xff)
date=99;
else if(count[cur]==0x85)
if(inc==0)
while(inc==0);
month++;
buz_on();
Lcd8_decimal2(count[cur],month);
if(month>=12)
month=0;
else if(dec==0)
while(!dec);
month--;
buz_on();
if(month==0xff)
month=99;
else if(count[cur]==0x8a)
if(inc==0)
while(!inc);
year++;
buz_on();
Lcd8_decimal2(count[cur],year);
if(year>99)
year=0;
else if(dec==0)
while(!dec);
year--;
buz_on();
if(year==0xff)
year=99;
else if(count[cur]==0x8d)
if(inc==0)
while(!inc);
day++;
buz_on();
//Lcd8_Command(0x01);
display_day();
Lcd8_decimal2(count[cur],day);
if(day>6)
day=0;
else if(dec==0)
while(!dec);
day--;
buz_on();
if(day==0xff)
day=7;
dd=dec_hex(date);
mn=dec_hex(month);
yy=dec_hex(year);
day=dec_hex(day);
DS1307_setdate(dd,mn,yy,day);
Lcd8_Command(0x0c);
puls();
void buz_on()
buz=0;
Delay(6500);
buz=1;
void time_set()
buz_on();
Lcd8_Command(Curser_Off);
Lcd8_Command(0x01);
Lcd8_Display(0x84,"Set Time",8);
cur=1;
while(set)
if(mov==0)
while(!mov);
cur++;
buz_on();
if(cur==2)
cur=0;
if(inc==0)
while(inc==0);
hour++;
buz_on();
Led8decimal2(hour);
if(hour>=25)
hour=0;
else if(dec==0)
while(!dec);
hour--;
buz_on();
Led8decimal2(hour);
if(hour==0)
hour=24;
if(inc==0)
while(inc==0);
min++;
buz_on();
Seg8_decimal2(min);
if(min>=60)
min=0;
else if(dec==0)
while(!dec);
min--;
buz_on();
Seg8_decimal2(min);
if(min==0xff)
min=31;
hh=rly_hex(hour);
mm=rly_hex(min);
DS1307_settime(hh,mm,ss);
void blink()
e4=0;
e3=0;
P3=0xff;
e4=1;
e3=1;
Delay(6500);
Led8decimal2(hour);
void alarm_set1()
no_puls();
ahour=EEPROM_ReadByte(0x01);
amin=EEPROM_ReadByte(0x02);
ahour1=EEPROM_ReadByte(0x03);
amin1=EEPROM_ReadByte(0x04);
Delay(10000);
buz_on();
Lcd8_Command(0x01);
Lcd8_Display(0x84,"NOW set",7);
Lcd8_Display(0xc0,"Regular schedule",17);
Delay(65000);
Lcd8_Command(0x01);
Lcd8_Display(0xc0,"Long bell times",15);
Delay(65000);
Delay(65000);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x82,"LB1)",4);
Lcd8_Display(0x88,":",1);
Lcd8_Display(0xc8,":",1);
Lcd8_decimal2(0x86,ahour);
Lcd8_decimal2(0x89,amin);
Lcd8_Display(0xc2,"LB2)",4);
Lcd8_decimal2(0xc6,ahour1);
Lcd8_decimal2(0xc9,amin1);
cur1=0;
while(set)
Lcd8_Command(0x0f);
Lcd8_Command(count1[cur1]);
if(mov==0)
while(!mov);
cur1++;
if(cur1==4)
cur1=0;
else if(count1[cur1]==0x86) ///1st line of lcd
if(inc==0)
while(inc==0);
ahour++;
buz_on();
if(ahour>=24)
ahour=0;
Lcd8_decimal2(count1[cur1],ahour);
else if(dec==0)
while(!dec);
ahour--;
buz_on();
if(ahour==0)
ahour=24;
else if(count1[cur1]==0x89)
if(inc==0)
while(inc==0);
amin++;
buz_on();
if(amin>=60)
amin=0;
Lcd8_decimal2(count1[cur1],amin);
else if(dec==0)
while(!dec);
amin--;
buz_on();
if(amin==0)
amin=60;
else if(count1[cur1]==0xc6)
if(inc==0)
while(inc==0);
ahour1++;
buz_on();
if(ahour1>=60)
ahour1=0;
Lcd8_decimal2(count1[cur1],ahour1);
else if(dec==0)
while(!dec);
ahour1--;
buz_on();
buz_on();
if(ahour1==0)
ahour1=24;
else if(count1[cur1]==0xc9)
if(inc==0)
while(inc==0);
amin1++;
buz_on();
if(amin1>=60)
amin1=0;
Lcd8_decimal2(count1[cur1],amin1);
else if(dec==0)
while(!dec);
amin1--;
buz_on();
buz_on();
if(amin1==0)
amin1=60;
Lcd8_Command(0x0c);
//Delay(65000);Delay(65000);
EEPROM_WriteByte(0x01, ahour);
EEPROM_WriteByte(0x02, amin);
EEPROM_WriteByte(0x03, ahour1);
EEPROM_WriteByte(0x04, amin1);
Lcd8_Command(0x01);
void alarm_set2()
ahour2=EEPROM_ReadByte(0x05);
amin2=EEPROM_ReadByte(0x06);
ahour3=EEPROM_ReadByte(0x07);
amin3=EEPROM_ReadByte(0x08);
buz_on();
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x82,"LB3)",4);
Lcd8_decimal2(0x86,ahour2);
Lcd8_decimal2(0x89,amin2);
Lcd8_Display(0xc2,"LB4)",4);
Lcd8_decimal2(0xc6,ahour3);
Lcd8_decimal2(0xc9,amin3);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==4)
cur1=0;
if(inc==0)
while(inc==0);
ahour2++;
buz_on();
if(ahour2>=24)
ahour2=0;
Lcd8_decimal2(count1[cur1],ahour2);
else if(dec==0)
while(!dec);
ahour2--;
buz_on();
buz_on();
if(ahour2==0)
ahour2=24;
if(inc==0)
while(inc==0);
amin2++;
buz_on();
if(amin2>=60)
amin2=0;
Lcd8_decimal2(count1[cur1],amin2);
else if(dec==0)
while(!dec);
amin2--;
buz_on();
if(amin2==0)
amin2=60;
if(inc==0)
while(inc==0);
ahour3++;
buz_on();
if(ahour1>=60)
ahour3=0;
Lcd8_decimal2(count1[cur1],ahour3);
else if(dec==0)
while(!dec);
ahour3--;
buz_on();
buz_on();
if(ahour3==0)
ahour3=24;
if(inc==0)
while(inc==0);
amin3++;
buz_on();
if(amin3>=60)
amin3=0;
Lcd8_decimal2(count1[cur1],amin3);
else if(dec==0)
while(!dec);
amin3--;
buz_on();
buz_on();
if(amin3==0)
amin3=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x05, ahour2);
EEPROM_WriteByte(0x06, amin2);
EEPROM_WriteByte(0x07, ahour3);
EEPROM_WriteByte(0x08, amin3);
Lcd8_Command(0x01);
void alarm_set3()
ahour4=EEPROM_ReadByte(0x09);
amin4=EEPROM_ReadByte(0x10);
ahour5=EEPROM_ReadByte(0x11);
amin5=EEPROM_ReadByte(0x12);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x82,"LB5)",4);
Lcd8_decimal2(0x86,ahour4);
Lcd8_decimal2(0x89,amin4);
Lcd8_Display(0xc2,"LB6)",4);
Lcd8_decimal2(0xc6,ahour5);
Lcd8_decimal2(0xc9,amin5);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==4)
cur1=0;
if(inc==0)
while(inc==0);
ahour4++;
buz_on();
if(ahour4>=24)
ahour4=0;
Lcd8_decimal2(count1[cur1],ahour4);
else if(dec==0)
while(!dec);
ahour4--;
buz_on();
buz_on();
if(ahour4==0)
ahour4=24;
if(inc==0)
while(inc==0);
amin4++;
buz_on();
if(amin2>=60)
amin4=0;
Lcd8_decimal2(count1[cur1],amin4);
else if(dec==0)
while(!dec);
amin4--;
buz_on();
if(amin2==0)
amin4=60;
if(inc==0)
while(inc==0);
ahour5++;
buz_on();
if(ahour5>=60)
ahour5=0;
Lcd8_decimal2(count1[cur1],ahour5);
else if(dec==0)
while(!dec);
ahour5--;
buz_on();
buz_on();
if(ahour5==0)
ahour5=24;
if(inc==0)
while(inc==0);
amin5++;
buz_on();
if(amin5>=60)
amin5=0;
Lcd8_decimal2(count1[cur1],amin5);
else if(dec==0)
while(!dec);
amin5--;
buz_on();
buz_on();
if(amin5==0)
amin5=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x09, ahour4);
EEPROM_WriteByte(0x10, amin4);
EEPROM_WriteByte(0x11, ahour5);
EEPROM_WriteByte(0x12, amin5);
Lcd8_Command(0x01);
void alarm_set4()
ahour6=EEPROM_ReadByte(0x13);
amin6=EEPROM_ReadByte(0x14);
ahour7=EEPROM_ReadByte(0x15);
amin7=EEPROM_ReadByte(0x16);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Display(0xc0,"short bell times",16);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x82,"SB1)",6);
Lcd8_decimal2(0x86,ahour6);
Lcd8_decimal2(0x89,amin6);
Lcd8_Display(0xc2,"SB2)",6);
Lcd8_decimal2(0xc6,ahour7);
Lcd8_decimal2(0xc9,amin7);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==4)
cur1=0;
if(inc==0)
while(inc==0);
ahour6++;
buz_on();
if(ahour6>=26)
ahour6=0;
Lcd8_decimal2(count1[cur1],ahour6);
else if(dec==0)
while(!dec);
ahour6--;
buz_on();
buz_on();
if(ahour6==0)
ahour6=24;
if(inc==0)
while(inc==0);
amin6++;
buz_on();
if(amin6>=60)
amin6=0;
Lcd8_decimal2(count1[cur1],amin6);
else if(dec==0)
while(!dec);
amin6--;
buz_on();
if(amin6==0)
amin6=60;
if(inc==0)
while(inc==0);
ahour7++;
buz_on();
if(ahour7>=60)
ahour7=0;
Lcd8_decimal2(count1[cur1],ahour7);
else if(dec==0)
while(!dec);
ahour7--;
buz_on();
buz_on();
if(ahour7==0)
ahour7=24;
if(inc==0)
while(inc==0);
amin7++;
buz_on();
if(amin7>=60)
amin7=0;
Lcd8_decimal2(count1[cur1],amin7);
else if(dec==0)
while(!dec);
amin7--;
buz_on();
buz_on();
if(amin7==0)
amin7=60;
Lcd8_Command(0x0c);
//Delay(67000);Delay(67000);
EEPROM_WriteByte(0x13, ahour6);
EEPROM_WriteByte(0x14, amin6);
EEPROM_WriteByte(0x15, ahour7);
EEPROM_WriteByte(0x16, amin7);
Lcd8_Command(0x01);
void alarm_set5()
ahour8=EEPROM_ReadByte(0x17);
amin8=EEPROM_ReadByte(0x18);
ahour9=EEPROM_ReadByte(0x19);
amin9=EEPROM_ReadByte(0x20);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x82,"SB3)",6);
Lcd8_decimal2(0x86,ahour8);
Lcd8_decimal2(0x89,amin8);
Lcd8_Display(0xc2,"SB4)",6);
Lcd8_decimal2(0xc6,ahour9);
Lcd8_decimal2(0xc9,amin9);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour8++;
buz_on();
if(ahour8>=26)
ahour8=0;
Lcd8_decimal2(count1[cur1],ahour8);
else if(dec==0)
while(!dec);
ahour8--;
buz_on();
buz_on();
if(ahour8==0)
ahour8=24;
if(inc==0)
while(inc==0);
amin8++;
buz_on();
if(amin8>=60)
amin8=0;
Lcd8_decimal2(count1[cur1],amin8);
else if(dec==0)
while(!dec);
amin8--;
buz_on();
if(amin8==0)
amin8=60;
if(inc==0)
while(inc==0);
ahour9++;
buz_on();
if(ahour9>=60)
ahour9=0;
Lcd8_decimal2(count1[cur1],ahour9);
else if(dec==0)
while(!dec);
ahour9--;
buz_on();
buz_on();
if(ahour9==0)
ahour9=24;
if(inc==0)
while(inc==0);
amin9++;
buz_on();
if(amin9>=60)
amin9=0;
Lcd8_decimal2(count1[cur1],amin9);
else if(dec==0)
while(!dec);
amin9--;
buz_on();
buz_on();
if(amin9==0)
amin9=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x17, ahour8);
EEPROM_WriteByte(0x18, amin8);
EEPROM_WriteByte(0x19, ahour9);
EEPROM_WriteByte(0x20, amin9);
Lcd8_Command(0x01);
void alarm_set6()
ahour10=EEPROM_ReadByte(0x21);
amin10=EEPROM_ReadByte(0x22);
ahour11=EEPROM_ReadByte(0x23);
amin11=EEPROM_ReadByte(0x24);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x82,"SB5)",6);
Lcd8_decimal2(0x86,ahour10);
Lcd8_decimal2(0x89,amin10);
Lcd8_Display(0xc2,"SB6)",6);
Lcd8_decimal2(0xc6,ahour11);
Lcd8_decimal2(0xc9,amin11);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour10++;
buz_on();
if(ahour10>=26)
ahour10=0;
Lcd8_decimal2(count1[cur1],ahour10);
else if(dec==0)
while(!dec);
ahour10--;
buz_on();
buz_on();
if(ahour10==0)
ahour10=24;
if(inc==0)
while(inc==0);
amin10++;
buz_on();
if(amin10>=60)
amin10=0;
Lcd8_decimal2(count1[cur1],amin10);
else if(dec==0)
while(!dec);
amin10--;
buz_on();
if(amin10==0)
amin10=60;
if(inc==0)
while(inc==0);
ahour11++;
buz_on();
if(ahour11>=60)
ahour11=0;
Lcd8_decimal2(count1[cur1],ahour11);
else if(dec==0)
while(!dec);
ahour11--;
buz_on();
buz_on();
if(ahour11==0)
ahour11=24;
if(inc==0)
while(inc==0);
amin11++;
buz_on();
if(amin11>=60)
amin11=0;
Lcd8_decimal2(count1[cur1],amin11);
else if(dec==0)
while(!dec);
amin11--;
buz_on();
buz_on();
if(amin11==0)
amin11=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x21, ahour10);
EEPROM_WriteByte(0x22, amin10);
EEPROM_WriteByte(0x23, ahour11);
EEPROM_WriteByte(0x24, amin11);
Lcd8_Command(0x01);
void alarm_set7()
ahour12=EEPROM_ReadByte(0x25);
amin12=EEPROM_ReadByte(0x26);
ahour13=EEPROM_ReadByte(0x27);
amin13=EEPROM_ReadByte(0x28);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x82,"SB7)",6);
Lcd8_decimal2(0x86,ahour12);
Lcd8_decimal2(0x89,amin12);
Lcd8_Display(0xc2,"SB8)",6);
Lcd8_decimal2(0xc6,ahour13);
Lcd8_decimal2(0xc9,amin13);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour12++;
buz_on();
if(ahour12>=26)
ahour12=0;
Lcd8_decimal2(count1[cur1],ahour12);
else if(dec==0)
while(!dec);
ahour12--;
buz_on();
buz_on();
if(ahour12==0)
ahour12=24;
if(inc==0)
while(inc==0);
amin12++;
buz_on();
if(amin2>=60)
amin12=0;
Lcd8_decimal2(count1[cur1],amin12);
else if(dec==0)
while(!dec);
amin12--;
buz_on();
if(amin2==0)
amin12=60;
if(inc==0)
while(inc==0);
ahour13++;
buz_on();
if(ahour13>=60)
ahour13=0;
Lcd8_decimal2(count1[cur1],ahour13);
else if(dec==0)
while(!dec);
ahour13--;
buz_on();
buz_on();
if(ahour13==0)
ahour13=24;
if(inc==0)
while(inc==0);
amin13++;
buz_on();
if(amin13>=60)
amin13=0;
Lcd8_decimal2(count1[cur1],amin13);
else if(dec==0)
while(!dec);
amin13--;
buz_on();
buz_on();
if(amin13==0)
amin13=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x25, ahour12);
EEPROM_WriteByte(0x26, amin12);
EEPROM_WriteByte(0x27, ahour13);
EEPROM_WriteByte(0x28, amin13);
Lcd8_Command(0x01);
void alarm_set8()
ahour14=EEPROM_ReadByte(0x29);
amin14=EEPROM_ReadByte(0x30);
ahour15=EEPROM_ReadByte(0x31);
amin15=EEPROM_ReadByte(0x32);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x82,"SB9)",4);
Lcd8_decimal2(0x86,ahour14);
Lcd8_decimal2(0x89,amin14);
Lcd8_Display(0xc1,"SB10)",5);
Lcd8_decimal2(0xc6,ahour15);
Lcd8_decimal2(0xc9,amin15);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour14++;
buz_on();
if(ahour14>=26)
ahour14=0;
Lcd8_decimal2(count1[cur1],ahour14);
else if(dec==0)
while(!dec);
ahour14--;
buz_on();
buz_on();
if(ahour14==0)
ahour14=24;
if(inc==0)
while(inc==0);
amin14++;
buz_on();
if(amin2>=60)
amin14=0;
Lcd8_decimal2(count1[cur1],amin14);
else if(dec==0)
while(!dec);
amin14--;
buz_on();
if(amin2==0)
amin14=60;
if(inc==0)
while(inc==0);
ahour15++;
buz_on();
if(ahour15>=60)
ahour15=0;
Lcd8_decimal2(count1[cur1],ahour15);
else if(dec==0)
while(!dec);
ahour15--;
buz_on();
buz_on();
if(ahour15==0)
ahour15=24;
if(inc==0)
while(inc==0);
amin15++;
buz_on();
if(amin15>=60)
amin15=0;
Lcd8_decimal2(count1[cur1],amin15);
else if(dec==0)
while(!dec);
amin15--;
buz_on();
buz_on();
if(amin15==0)
amin15=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x29, ahour14);
EEPROM_WriteByte(0x30, amin14);
EEPROM_WriteByte(0x31, ahour15);
EEPROM_WriteByte(0x32, amin15);
Lcd8_Command(0x01);
void alarm_set9()
ahour16=EEPROM_ReadByte(0x33);
amin16=EEPROM_ReadByte(0x34);
ahour17=EEPROM_ReadByte(0x35);
amin17=EEPROM_ReadByte(0x36);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x81,"SB11)",6);
Lcd8_decimal2(0x86,ahour16);
Lcd8_decimal2(0x89,amin16);
Lcd8_Display(0xc1,"SB12)",6);
Lcd8_decimal2(0xc6,ahour17);
Lcd8_decimal2(0xc9,amin17);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour16++;
buz_on();
if(ahour16>=26)
ahour16=0;
Lcd8_decimal2(count1[cur1],ahour16);
else if(dec==0)
while(!dec);
ahour16--;
buz_on();
buz_on();
if(ahour16==0)
ahour16=24;
if(inc==0)
while(inc==0);
amin16++;
buz_on();
if(amin2>=60)
amin16=0;
Lcd8_decimal2(count1[cur1],amin16);
else if(dec==0)
while(!dec);
amin16--;
buz_on();
if(amin16==0)
amin16=60;
if(inc==0)
while(inc==0);
ahour17++;
buz_on();
if(ahour17>=60)
ahour17=0;
Lcd8_decimal2(count1[cur1],ahour17);
else if(dec==0)
while(!dec);
ahour17--;
buz_on();
buz_on();
if(ahour17==0)
ahour17=24;
if(inc==0)
while(inc==0);
amin17++;
buz_on();
if(amin17>=60)
amin17=0;
Lcd8_decimal2(count1[cur1],amin17);
else if(dec==0)
while(!dec);
amin17--;
buz_on();
buz_on();
if(amin17==0)
amin17=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x33, ahour16);
EEPROM_WriteByte(0x34, amin16);
EEPROM_WriteByte(0x35, ahour17);
EEPROM_WriteByte(0x36, amin17);
Lcd8_Command(0x01);
void alarm_set10()
ahour=EEPROM_ReadByte(0x37);
amin=EEPROM_ReadByte(0x38);
ahour1=EEPROM_ReadByte(0x39);
amin1=EEPROM_ReadByte(0x40);
Delay(10000);
buz_on();
Lcd8_Command(0x01);
Lcd8_Display(0xc0,"Friday schedule",16);
Delay(65000);
Lcd8_Command(0x01);
Delay(65000);
Delay(65000);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==4)
cur1=0;
if(inc==0)
while(inc==0);
ahour++;
buz_on();
if(ahour>=24)
ahour=0;
else if(dec==0)
while(!dec);
ahour--;
buz_on();
if(ahour==0)
ahour=24;
if(inc==0)
while(inc==0);
amin++;
buz_on();
if(amin>=60)
amin=0;
else if(dec==0)
while(!dec);
amin--;
buz_on();
if(amin==0)
amin=60;
if(inc==0)
while(inc==0);
ahour1++;
buz_on();
if(ahour1>=60)
ahour1=0;
else if(dec==0)
while(!dec);
ahour1--;
buz_on();
buz_on();
if(ahour1==0)
ahour1=24;
if(inc==0)
while(inc==0);
amin1++;
buz_on();
if(amin1>=60)
amin1=0;
else if(dec==0)
while(!dec);
amin1--;
buz_on();
buz_on();
if(amin1==0)
amin1=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x37, ahour);
EEPROM_WriteByte(0x38, amin);
EEPROM_WriteByte(0x39, ahour1);
EEPROM_WriteByte(0x40, amin1);
Lcd8_Command(0x01);
void alarm_set11()
ahour2=EEPROM_ReadByte(0x41);
amin2=EEPROM_ReadByte(0x42);
ahour3=EEPROM_ReadByte(0x43);
amin3=EEPROM_ReadByte(0x44);
buz_on();
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==4)
cur1=0;
if(inc==0)
while(inc==0);
ahour2++;
buz_on();
if(ahour2>=24)
ahour2=0;
else if(dec==0)
while(!dec);
ahour2--;
buz_on();
buz_on();
if(ahour2==0)
ahour2=24;
if(inc==0)
while(inc==0);
amin2++;
buz_on();
if(amin2>=60)
amin2=0;
else if(dec==0)
while(!dec);
amin2--;
buz_on();
if(amin2==0)
amin2=60;
if(inc==0)
while(inc==0);
ahour3++;
buz_on();
if(ahour1>=60)
ahour3=0;
else if(dec==0)
while(!dec);
ahour3--;
buz_on();
buz_on();
if(ahour3==0)
ahour3=24;
if(inc==0)
while(inc==0);
amin3++;
buz_on();
if(amin3>=60)
amin3=0;
else if(dec==0)
while(!dec);
amin3--;
buz_on();
buz_on();
if(amin3==0)
amin3=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x41, ahour2);
EEPROM_WriteByte(0x42, amin2);
EEPROM_WriteByte(0x43, ahour3);
EEPROM_WriteByte(0x44, amin3);
Lcd8_Command(0x01);
void alarm_set12()
ahour4=EEPROM_ReadByte(0x45);
amin4=EEPROM_ReadByte(0x46);
ahour5=EEPROM_ReadByte(0x47);
amin5=EEPROM_ReadByte(0x48);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==4)
cur1=0;
if(inc==0)
while(inc==0);
ahour4++;
buz_on();
if(ahour4>=24)
ahour4=0;
else if(dec==0)
while(!dec);
ahour4--;
buz_on();
buz_on();
if(ahour4==0)
ahour4=24;
if(inc==0)
while(inc==0);
amin4++;
buz_on();
if(amin2>=60)
amin4=0;
else if(dec==0)
while(!dec);
amin4--;
buz_on();
if(amin2==0)
amin4=60;
if(inc==0)
while(inc==0);
ahour5++;
buz_on();
if(ahour5>=60)
ahour5=0;
else if(dec==0)
while(!dec);
ahour5--;
buz_on();
buz_on();
if(ahour5==0)
ahour5=24;
if(inc==0)
while(inc==0);
amin5++;
buz_on();
if(amin5>=60)
amin5=0;
else if(dec==0)
while(!dec);
amin5--;
buz_on();
buz_on();
if(amin5==0)
amin5=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x45, ahour4);
EEPROM_WriteByte(0x46, amin4);
EEPROM_WriteByte(0x47, ahour5);
EEPROM_WriteByte(0x48, amin5);
Lcd8_Command(0x01);
void alarm_set13()
ahour6=EEPROM_ReadByte(0x49);
amin6=EEPROM_ReadByte(0x50);
ahour7=EEPROM_ReadByte(0x51);
amin7=EEPROM_ReadByte(0x52);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==4)
cur1=0;
if(inc==0)
while(inc==0);
ahour6++;
buz_on();
if(ahour6>=26)
ahour6=0;
else if(dec==0)
while(!dec);
ahour6--;
buz_on();
buz_on();
if(ahour6==0)
ahour6=24;
if(inc==0)
while(inc==0);
amin6++;
buz_on();
if(amin2>=60)
amin6=0;
else if(dec==0)
while(!dec);
amin6--;
buz_on();
if(amin6==0)
amin6=60;
if(inc==0)
while(inc==0);
ahour7++;
buz_on();
if(ahour7>=60)
ahour7=0;
else if(dec==0)
while(!dec);
ahour7--;
buz_on();
buz_on();
if(ahour7==0)
ahour7=24;
if(inc==0)
while(inc==0);
amin7++;
buz_on();
if(amin7>=60)
amin7=0;
else if(dec==0)
while(!dec);
amin7--;
buz_on();
buz_on();
if(amin7==0)
amin7=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x49, ahour6);
EEPROM_WriteByte(0x50, amin6);
EEPROM_WriteByte(0x51, ahour7);
EEPROM_WriteByte(0x52, amin7);
Lcd8_Command(0x01);
void alarm_set14()
ahour8=EEPROM_ReadByte(0x53);
amin8=EEPROM_ReadByte(0x54);
ahour9=EEPROM_ReadByte(0x55);
amin9=EEPROM_ReadByte(0x56);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour8++;
buz_on();
if(ahour8>=26)
ahour8=0;
else if(dec==0)
while(!dec);
ahour8--;
buz_on();
buz_on();
if(ahour8==0)
ahour8=24;
if(inc==0)
while(inc==0);
amin8++;
buz_on();
if(amin8>=60)
amin8=0;
else if(dec==0)
while(!dec);
amin8--;
buz_on();
if(amin8==0)
amin8=60;
if(inc==0)
while(inc==0);
ahour9++;
buz_on();
if(ahour9>=60)
ahour9=0;
else if(dec==0)
while(!dec);
ahour9--;
buz_on();
buz_on();
if(ahour9==0)
ahour9=24;
if(inc==0)
while(inc==0);
amin9++;
buz_on();
if(amin9>=60)
amin9=0;
else if(dec==0)
while(!dec);
amin9--;
buz_on();
buz_on();
if(amin9==0)
amin9=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x53, ahour8);
EEPROM_WriteByte(0x54, amin8);
EEPROM_WriteByte(0x55, ahour9);
EEPROM_WriteByte(0x56, amin9);
Lcd8_Command(0x01);
void alarm_set15()
ahour10=EEPROM_ReadByte(0x57);
amin10=EEPROM_ReadByte(0x58);
ahour11=EEPROM_ReadByte(0x59);
amin11=EEPROM_ReadByte(0x60);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour10++;
buz_on();
if(ahour10>=26)
ahour10=0;
else if(dec==0)
while(!dec);
ahour10--;
buz_on();
buz_on();
if(ahour10==0)
ahour10=24;
if(inc==0)
while(inc==0);
amin10++;
buz_on();
if(amin10>=60)
amin10=0;
else if(dec==0)
while(!dec);
amin10--;
buz_on();
if(amin10==0)
amin10=60;
if(inc==0)
while(inc==0);
ahour11++;
buz_on();
if(ahour11>=60)
ahour11=0;
else if(dec==0)
while(!dec);
ahour11--;
buz_on();
buz_on();
if(ahour11==0)
ahour11=24;
if(inc==0)
while(inc==0);
amin11++;
buz_on();
if(amin11>=60)
amin11=0;
else if(dec==0)
while(!dec);
amin11--;
buz_on();
buz_on();
if(amin11==0)
amin11=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x57, ahour10);
EEPROM_WriteByte(0x58, amin10);
EEPROM_WriteByte(0x59, ahour11);
EEPROM_WriteByte(0x60, amin11);
Lcd8_Command(0x01);
void alarm_set16()
ahour12=EEPROM_ReadByte(0x61);
amin12=EEPROM_ReadByte(0x62);
ahour13=EEPROM_ReadByte(0x63);
amin13=EEPROM_ReadByte(0x64);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour12++;
buz_on();
if(ahour12>=26)
ahour12=0;
else if(dec==0)
while(!dec);
ahour12--;
buz_on();
buz_on();
if(ahour12==0)
ahour12=24;
if(inc==0)
while(inc==0);
amin12++;
buz_on();
if(amin2>=60)
amin12=0;
else if(dec==0)
while(!dec);
amin12--;
buz_on();
if(amin2==0)
amin12=60;
if(inc==0)
while(inc==0);
ahour13++;
buz_on();
if(ahour13>=60)
ahour13=0;
else if(dec==0)
while(!dec);
ahour13--;
buz_on();
buz_on();
if(ahour13==0)
ahour13=24;
if(inc==0)
while(inc==0);
amin13++;
buz_on();
if(amin13>=60)
amin13=0;
else if(dec==0)
while(!dec);
amin13--;
buz_on();
buz_on();
if(amin13==0)
amin13=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x61, ahour12);
EEPROM_WriteByte(0x62, amin12);
EEPROM_WriteByte(0x63, ahour13);
EEPROM_WriteByte(0x64, amin13);
Lcd8_Command(0x01);
void alarm_set17()
ahour14=EEPROM_ReadByte(0x65);
amin14=EEPROM_ReadByte(0x66);
ahour15=EEPROM_ReadByte(0x67);
amin15=EEPROM_ReadByte(0x68);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour14++;
buz_on();
if(ahour14>=26)
ahour14=0;
else if(dec==0)
while(!dec);
ahour14--;
buz_on();
buz_on();
if(ahour14==0)
ahour14=24;
if(inc==0)
while(inc==0);
amin14++;
buz_on();
if(amin2>=60)
amin14=0;
else if(dec==0)
while(!dec);
amin14--;
buz_on();
if(amin2==0)
amin14=60;
if(inc==0)
while(inc==0);
ahour15++;
buz_on();
if(ahour15>=60)
ahour15=0;
else if(dec==0)
while(!dec);
ahour15--;
buz_on();
buz_on();
if(ahour15==0)
ahour15=24;
if(inc==0)
while(inc==0);
amin15++;
buz_on();
if(amin15>=60)
amin15=0;
else if(dec==0)
while(!dec);
amin15--;
buz_on();
buz_on();
if(amin15==0)
amin15=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x65, ahour14);
EEPROM_WriteByte(0x66, amin14);
EEPROM_WriteByte(0x67, ahour15);
EEPROM_WriteByte(0x68, amin15);
Lcd8_Command(0x01);
void alarm_set18()
ahour16=EEPROM_ReadByte(0x69);
amin16=EEPROM_ReadByte(0x70);
ahour17=EEPROM_ReadByte(0x71);
amin17=EEPROM_ReadByte(0x72);
buz_on();
//Delay(65000);
Delay(10000);
Lcd8_Command(0x01);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour16++;
buz_on();
if(ahour16>=26)
ahour16=0;
else if(dec==0)
while(!dec);
ahour16--;
buz_on();
buz_on();
if(ahour16==0)
ahour16=24;
if(inc==0)
while(inc==0);
amin16++;
buz_on();
if(amin2>=60)
amin16=0;
else if(dec==0)
while(!dec);
amin16--;
buz_on();
if(amin16==0)
amin16=60;
if(inc==0)
while(inc==0);
ahour17++;
buz_on();
if(ahour17>=60)
ahour17=0;
else if(dec==0)
while(!dec);
ahour17--;
buz_on();
buz_on();
if(ahour17==0)
ahour17=24;
if(inc==0)
while(inc==0);
amin17++;
buz_on();
if(amin17>=60)
amin17=0;
else if(dec==0)
while(!dec);
amin17--;
buz_on();
buz_on();
if(amin17==0)
amin17=60;
Lcd8_Command(0x0c);
EEPROM_WriteByte(0x69, ahour16);
EEPROM_WriteByte(0x70, amin16);
EEPROM_WriteByte(0x71, ahour17);
EEPROM_WriteByte(0x72, amin17);
Lcd8_Command(0x01);
void alarm_chk1()
amin11=EEPROM_ReadByte(0x24); //0x34
if(hour==ahour)
if(min==amin)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour1)
if(min==amin1)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour2)
if(min==amin2)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour3)
if(min==amin3)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour4)
if(min==amin4)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour5)
if(min==amin5)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour6)
if(min==amin6)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour7)
if(min==amin7)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour8)
if(min==amin8)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour9)
if(min==amin9)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour10)
if(min==amin10)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour11)
if(min==amin11)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour12)
if(min==amin12)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour13)
if(min==amin13)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour14)
if(min==amin14)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour15)
if(min==amin15)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour16)
if(min==amin16)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
void alarm_chk2()
ahour=EEPROM_ReadByte(0x35);
amin=EEPROM_ReadByte(0x36);
ahour1=EEPROM_ReadByte(0x37);
amin1=EEPROM_ReadByte(0x38);
ahour2=EEPROM_ReadByte(0x39);
amin2=EEPROM_ReadByte(0x40);
ahour3=EEPROM_ReadByte(0x41);
amin3=EEPROM_ReadByte(0x42);
ahour4=EEPROM_ReadByte(0x43);
amin4=EEPROM_ReadByte(0x44);
ahour5=EEPROM_ReadByte(0x45);
amin5=EEPROM_ReadByte(0x46);
ahour6=EEPROM_ReadByte(0x47);
amin6=EEPROM_ReadByte(0x48);
ahour7=EEPROM_ReadByte(0x49);
amin7=EEPROM_ReadByte(0x50);
ahour8=EEPROM_ReadByte(0x51);
amin8=EEPROM_ReadByte(0x52);
ahour9=EEPROM_ReadByte(0x53);
amin9=EEPROM_ReadByte(0x54);
ahour10=EEPROM_ReadByte(0x55);
amin10=EEPROM_ReadByte(0x56);
ahour11=EEPROM_ReadByte(0x57);
amin11=EEPROM_ReadByte(0x58);
ahour12=EEPROM_ReadByte(0x59);
amin12=EEPROM_ReadByte(0x60);
ahour13=EEPROM_ReadByte(0x61);
amin13=EEPROM_ReadByte(0x62);
ahour14=EEPROM_ReadByte(0x63);
amin14=EEPROM_ReadByte(0x64);
ahour15=EEPROM_ReadByte(0x65);
amin15=EEPROM_ReadByte(0x66);
ahour16=EEPROM_ReadByte(0x67);
amin16=EEPROM_ReadByte(0x68);
if(hour==ahour)
if(min==amin)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour1)
if(min==amin1)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour2)
if(min==amin2)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour3)
if(min==amin3)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour4)
if(min==amin4)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour5)
if(min==amin5)
if(sec==asec)
alarm_bell_HI();
else
rly=1;
if(hour==ahour6)
if(min==amin6)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour7)
if(min==amin7)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour8)
if(min==amin8)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour9)
if(min==amin9)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour10)
if(min==amin10)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour11)
if(min==amin11)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour12)
if(min==amin12)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour13)
if(min==amin13)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour14)
if(min==amin14)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour15)
if(min==amin15)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
if(hour==ahour16)
if(min==amin16)
if(sec==asec)
alarm_bell_LOW();
else
rly=1;
Lcd8_Command(0x01);
Lcd8_Display(0xc0,"Bell ringing.. ",14);
rly=0;
rly=1;
Lcd8_Command(0x01);
rly=0;
Delay(65000);
Delay(65000);
rly=1;
void Lcd8_Init()
Lcd8_Command(0x38); //to select function set
Lcd8_Command(0x06); //entry mode set
Lcd8_Command(0x0c); //display on
Lcd8_Command(0x01); //clear display
void Lcd8_Command(unsigned char com)
Data_Port=com;
Lcd_en=1;
Lcd_rs=0;
//Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Write(unsigned char com,unsigned char lr)
Lcd8_Command(com);
Data_Port=lr; // Data
Lcd_en=Lcd_rs=1;
//Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Display(unsigned char com,const unsigned char *word,unsigned int n)
unsigned char Lcd_i;
for(Lcd_i=0;Lcd_i<n;Lcd_i++)
Lcd8_Write(com+Lcd_i,word[Lcd_i]);
void Lcd8_decimal2(unsigned char com,unsigned char val)
unsigned int Lcd_hr,Lcd_t,Lcd_o;
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_t+0x30);
Lcd8_Write(com+1,Lcd_o+0x30);
void Delay(unsigned int del)
while(del--);
Lcd_hr=min%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
e5=0;
P3=Lcd_t+0x30;
e5=1;
e6=0;
P3=Lcd_o+0x30;
e6=1;
Lcd_hr=hour%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
e4=0;
P3=Lcd_t+0x30;
e4=1;
e3=0;
P3=Lcd_o+0x30;
e3=1;
/*********************************LCD HEADER FILE END*************************************/
/*********************************RTC HEADER FILE START*********************************/
DS1307_get(unsigned char addr)
unsigned char ret;
Rtc_Start();
ret = Rtc_Read(addr);
Rtc_Stop();
return ret;
void DS1307_settime(unsigned char hh, unsigned char mm, unsigned char ss)
Rtc_Start();
Rtc_Write(0x00,ss); /* Write sec on RAM address 00H */
Rtc_Write(0x01,mm); /* Write min on RAM address 01H */
Rtc_Write(0x02,hh); /* Write hour on RAM address 02H */
void DS1307_setdate(unsigned char dd, unsigned char mm, unsigned char yy,unsigned char day)
Rtc_Start();
Rtc_Write(0x04,dd); /* Write date on RAM address 04H */
Rtc_Write(0x05,mm); /* Write month on RAM address 05H */
Rtc_Write(0x06,yy); /* Write year on RAM address 06H */
Rtc_Write(0x03,day); /* Write year on RAM address 03H */
Send2lcd(unsigned char value)
unsigned char buf1,buf2,buf = 0;
buf1 = value & 0xF0; /* Filter for high byte */
buf1 = (buf1>>4); /* Convert to ascii code */
buf2 = value & 0x0F; /* Filter for low byte */
buf=(buf1*10)+buf2;
return buf;
void Rtc_Init()//lower order 256 bytes of the chip
Rtc_add_wr=0xd0;
Rtc_add_rd=0xd1;
void Rtc_Write(unsigned char zig,unsigned char zag)// program to write to EEPROM
dat_rtc=zig;
temp_rtc=zag;
Rtc_rd_wr_sub();
above:
d_rtc=temp_rtc;
Rtc_Tx();
if (CY==1)goto above;
CY=0;
Rtc_Stop();
Rtc_Read(unsigned char zig)// program to read from EEPROM
dat_rtc=zig;
Rtc_rd_wr_sub();
Rtc_Start();
be:
d_rtc=Rtc_add_rd; // 0xd1 =Rtc_add_rd
Rtc_Tx();
if(CY==1)goto be;
Rtc_Rx();
Rtc_Ack();
CY=0;
Rtc_Stop();
return(datain_rtc);
void Rtc_Start()// must for any operation on EEPROM
sda_rtc=1;
scl_rtc=1;
sda_rtc=0;
scl_rtc=0;
void Rtc_Stop()// this is similar to the START operation whereas this should be performed after the completion of any operation
sda_rtc=0;
scl_rtc=1;
sda_rtc=1;
void Rtc_Tx()// program to send the device address, read/write address,data to be written
signed char i_rtc;
for(i_rtc=7;i_rtc>=0;i_rtc--)// should necessarily be initialised as signed char.
CY=(d_rtc>>i_rtc)&0x01;
sda_rtc=CY;
scl_rtc=1;// clock is essential inorder to write or read
scl_rtc=0;// clk should be alternated
sda_rtc=1;
scl_rtc=1;
CY=sda_rtc;
scl_rtc=0;
void Rtc_Rx()// program read the data from the EEPROM
unsigned char l_rtc;
sda_rtc=1;
for (l_rtc=0;l_rtc<=7;l_rtc++)
scl_rtc=1;
in_rtc=in_rtc<<1;
in_rtc|=sda_rtc;
scl_rtc=0;
datain_rtc=in_rtc;
in_rtc=0;
void Rtc_Ack()// this is to intimate the EEPROM that the read operation is over
sda_rtc=1;
scl_rtc=1;
scl_rtc=0;
void Rtc_rd_wr_sub()// this routine will be used by both the read & write operations to send the device address & the address at which the corresponding action is to be taken
Rtc_Start();
here1:
d_rtc=Rtc_add_wr;// 0xd0 device address is passed
Rtc_Tx();
if(CY==1)goto here1;
again1:
d_rtc=dat_rtc;// the address from which data is to be read/written is to be passed
Rtc_Tx();
if(CY==1)goto again1;
I2C_Start(); // Start i2c communication
I2C_Write(EEPROM_ID); // connect to AT2404 by sending its ID on I2c Bus
I2C_Ack();
I2C_Write(eeprom_Address); // Select the Specified EEPROM address of AT2404
I2C_Ack();
I2C_Write(eeprom_Data); // Write the data at specified address
I2C_Ack();
I2C_Stop(); // Stop i2c communication after Writing the data
delay_ms(1); // Write operation takes max 5ms, refer At2404 datasheet
unsigned char eeprom_Data;
I2C_Write(EEPROM_ID); // connect to AT2404(write) by sending its ID on I2c Bus
I2C_Ack();
I2C_Ack();
I2C_Write(0xA1); // connect to AT2404(read) by sending its ID on I2c Bus
I2C_Ack();
eeprom_Data = I2C_Read(); // Read the data from specified address
I2C_NoAck();
I2C_Stop(); // Stop i2c communication after Reading the data
delay_us(10);
return eeprom_Data; // Return the Read data
void I2C_Start()
SCL = 0; // Pull SCL low
SDA = 1; // Pull SDA High
delay_us(1);
SCL = 1; //Pull SCL high
delay_us(1);
SDA = 0; //Now Pull SDA LOW, to generate the Start Condition
delay_us(1);
SCL = 0; //Finally Clear the SCL to complete the cycle
void I2C_Stop(void)
delay_us(1);
SDA = 0; // Pull SDA low
delay_us(1);
SCL = 1; // Pull SCL High
delay_us(1);
SDA = 1; // Now Pull SDA High, to generate the Stop Condition
void I2C_Ack()
SDA = 0; //Pull SDA low to indicate Positive ACK
I2C_Clock(); //Generate the Clock
SDA = 1; // Pull SDA back to High(IDLE state)
void I2C_NoAck()
SDA = 1; //Pull SDA high to indicate Negative/NO ACK
I2C_Clock(); // Generate the Clock
SCL = 1; // Set SCL */
unsigned char i;
for(i=0;i<8;i++) // loop 8 times to send 1-byte of data
SDA = dat & 0x80; // Send Bit by Bit on SDA line
I2C_Clock(); // Generate Clock at SCL
dat = dat<<1;
SDA = 1; // Set SDA at last
unsigned char I2C_Read(void)
unsigned char i, dat=0x00;
SDA=1; //Make SDA as I/P
for(i=0;i<8;i++) // loop 8times to read 1-byte of data
delay_us(1);
delay_us(1);
dat = dat<<1; //dat is Shifted each time and
dat = dat | SDA; //ORed with the received bit to pack into byte
SCL = 0; // Clear SCL to complete the Clock
return dat; // Finally return the received Byte*
while(ms_count!=0)
delay_us(112); //delay_us is called to generate 1ms delay
ms_count--;
while(us_count!=0)
us_count--;
void I2C_Clock(void)
delay_us(1);
SCL = 1; // Wait for Some time and Pull the SCL line High
delay_us(1); // Wait for Some time
SCL = 0; // Pull back the SCL line low to Generate a clock pulse
