strengthever
Because a friend of mine tested continuity of chip using a fluke Multimeter with osciloscopy on my dell and no continuity, but the main problem i found until now, faulty power rail from mobo from dell.......damn!!
Hello guys, I've read through the thread and cannot find the links for the motherboard schematics... I also have a Dell M1330 that went dead, and is out of warranty. I am pretty sure that if I find out which capacitor died I can replace it, but the motherboard schematic would cut a lot of the work from the job. Also, since some of you have done this successfully, I would absolutely appreciate a guide based on your experiences...
Thanks for your replies... I know this is an old post, but I am sort of desperate and DELL wants to charge me $400 for the repair. (I would rather spend $200 more and get a different laptop, considering this one has issues to start with). If I can fix it, it would be awesome.
E.
I just repaired mine, you will need an infra red camera to detect which capacitor is short,mine was also a ceramic 10u (C521 ) but others have reported other caps (C10 for example). With the camera it's an easy job.
When I opened my laptop to check the caps, I found that, indeed, C10 (right beside the battery connector) seemed damaged. I replaced it with another R10 Cap, and it turned on, the job, however, was less that perfect, since the cap I had left some bulge due to space restrictions. I found a better solution by ORDERING the DT2 Charger Board (Part 48.4C302.031 06602-3) from Amazon, which replaces the entire charger board part of the motherboard. The part arrived today and I did the replacement job, needing only patience and a phillips screw driver. I noticed that the new part did have all capacitors in "new" condition, whereas my old part was missing one, had one obviously soldered on to replace a damaged one, and had a bad one from stress (C10). So to anyone experiencing this problem, It is better to simply order the part and install it, the part cost me US$49.00.
Good luck and thanks to everyone for their help.
E.
Thanks for the very helpful info. Just want to confirm that the capacitor C10 is actually located on the power rail/charger board part of the motherboard. Can anyone confirm this?
I replaced a C10 that was actually on the motherboard itself. It is right beside the connector that mates the charging board and the motherboard.
Good stuff....much appreciated. From "elfman1977"'s post it sounded like he purchased a new charger board thinking C10 was located on it but thanks for clarifying that it's actually on the motherboard. What is the chance that some of the capacitors on the rail are bad?! I knew I should have taken some electrical course when I was younger!!
Sorry but one more thing....where can I grab a capacitor like this from? C10 (10uF 25V 1206 X5R ).
Hello I searching for Dell M1330 ModelP25L schematic of motherboard because my mobo is dead and I want to repair it.
If someone know what are parameters of R010 please inform me because I want to buy it and change it.
Another thing what I searching for are fuses on this boards how can I search for it's on this mobo.
