[PIC] Delay routine drifting
I reviewed the thread, expecting to find a clear description of the observed "delay drifting" or how it's been detected, but to no avail.
May be you are chasing a phantom?
Ok guys let's restart.
I think was chaching phantoms.
Ive writen the following and i can't get a precise 1ms routine.
Can someone tell me whats wrong ?
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
#include <pic12f1822.h>
/* Setup chip configuration */
__code int __at(_CONFIG1) __CONFIG = _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF;
void setup(void);
void delay_ms(int milis);
volatile unsigned char done;
static void isr(void) __interrupt 0 {
    if(TMR0IE==1 && TMR0IF==1)//timer 1 interrupt overflow detect
        done = 1; //latch enable as soon as interrupt detected
        TMR0IF = 0;//clear overflow flag
void main(void) {
    setup();
    while(1) {
        delay_ms(1000);
        LATA |= (1<<2);
        delay_ms(1000);
        LATA &= ~(1<<2);
void setup(void) {
    OSCCON = 0b01011000; // 1MHZ internal clock
    LATA = 0;
    TRISA = 0x00;
    PORTA = 0x00;
//  Clock source selection (Fosc/4)
    TMR0CS = 0;
    PSA = 1;    // No prescaler
//  Enable Timer1 interrupt
    TMR0IE = 1;
    GIE = 1;
void delay_ms(int milis) {
    while (milis--) {
        done = 0; //disable delay latch
        TMR0 = 250;  //
        while (!done);  //latch till 1ms interrupt happens
hello,
FOSC=1Mhz => cycle=4µS
there is a mistake on timer0 init value ..
and reinit timer0 inside interrupt , else you will add some cycles (x * 4µs)
       [B] TMR0 = 5[/B];  // reinit timer0 immediatly, because must continue to count elapsed time
void main(void) {
    setup();
    while(1) {
        delay_ms(1000);
        LATA |= (1<<2);
        delay_ms(1000);
        LATA &= ~(1<<2);
void setup(void) {
    LATA = 0;
    TRISA = 0x00;
    PORTA = 0x00;
    TMR0CS = 0;
    TMR0 = 5;  /
    TMR0IE = 1;
    GIE = 1;
    while (milis--) {
       // TMR0 = 250;  // allready done inside  interrupt
My bad paulfjujo,
New code :
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
void setup(void);
void main(void) {
    setup();
    while(1) {
        delay_ms(1000);
        LATA |= (1<<2);
        delay_ms(1000);
        LATA &= ~(1<<2);
void setup(void) {
    LATA = 0;
    TRISA = 0x00;
    PORTA = 0x00;
    TMR0CS = 0;
//  TMR0IE = 1;
//  GIE = 1;
    while (milis--) {
        TMR0 = 6;  //
        while (!TMR0IF);  //latch till 1ms interrupt happens
        TMR0IF = 0;
