KD494
Member level 5
- Joined
- Jun 24, 2015
- Messages
- 83
- Helped
- 13
- Reputation
- 26
- Reaction score
- 13
- Trophy points
- 1,288
- Location
- Boston, MA
- Activity points
- 2,059
Hello!
I'm having an issue with the attached schematic, and I can't work out what the mistake is. The intention of Q1 is to save battery life by only powering up the micro after the user presses one of the 3 switches (SW1-SW3). Once the user holds a button long enough to power the micro, it will immediately set I/O D6 low to keep Q1 on, and when it decides its time to power off it will write pin D6 high.
However, as soon as I insert the batteries the micro powers up, which means Q1 must inadvertently be turned on. Everything I can find about the micro indicates the I/O should be high Z when it is powered off, so I dont understand how Q1 is being enhanced. It does seem like the micro is not receiving the full 4.5V because the LED on board is extremely dim, and lights up to full brightness when I do press a button. Is there something I'm missing that could be allowing Q1 to pass current.
Thanks in advance!
Thanks in advance!
