DC motor H bridge current waveform
anotherbrick
Full Member level 4
Full Member level 4
Istanbul , Turkey
hi dear forum members
my question in the picture
thank you
Let us hope the other 100k resistors you have not corrected in the new picture are not 100k any more ?
for your mosfets, 0.0046 ohm x 1.5 x 30^2 = 6.21 watts, / 2 = 3.1 watts each, as on half the time
this is 12 - 15 watts for all 4 fets, perhaps surprisingly you need a lot of heatsink to keep the Trise down at 15 watts, especially if the ambient is 30 -40 deg C
It appears your simple plate is not up to the job, so you need a proper heatsink, if you double up the mosfets you will get to 7 watts ( + sw losses ) which will likely be a lot better.
LaTeX Commands Quick-Menu:
