DC-DC output voltage dropping due to RF noise
biswaIITH
Full Member level 4
Full Member level 4
Hyderabad
We are facing an issue where the output of the DC-DC(12V) drops to 1-2 V for few milliseconds when an SOM module tries connecting with the cloud. The DC-DC is designed using LM5146 IC from texas instruments
This is mostly due to RF noise we suspect.
Can anyone suggest any shielding technique to prevent the above?
Solution
What is the power source for the DC/DC converter ? - if this cannot supply the power needed by the system ( 140 W by your estimate at full power ) the you will have the issues you are seeing.
Does anyone see any problems with this Feedback gain and slope?
I would significantly reduce the 24k to boost error-correction gain in the <1ms pulse range.
After Changing the R11 to 5.1K & R18 to 18K. The voltage drop issue is not happening. However, we have been continuously testing the board for the last 2 days.Will update further
Thanks for confirming my recommendation.
You can test a step load in both directions, on/off for over/undershoot and then define your performance specs you want to guarantee.
LaTeX Commands Quick-Menu:
