NealG
Newbie level 2
Hello,
I am trying to build a temperature control circuit. The output should be DC (current or voltage) and is fed to a heater blanket. The system should be able to supply ~15W with a 24V supply at max output. Originally, I was planning to use a 20 or 24 bit DAC then amplify; essentially, a DAC controlled DC current source.
To help with the linearity of the system identification that I will have to do, I would like the output of my controller to be a proxy for power. Either V^2 or I^2 is fine. Here is the part that I would like some advice about: what is the best way to realize this?
- I could add a layer of abstraction in my approach to restrict the output states. Instead of 0-2^24-1 states, I could restrict it to 0:2^2^12-1 states where each state is actually S^2 but this would reduce my resolution to 12 bits (using a 24 bit DAC)
- I could use an IC like AD633 analog multiplier but somehow this seems like overkill
- I have searched for DACs with nonlinear outputs but didn't find much
- Could an DC to RMS conversion circuit be used?
Is there a simpler realization that I'm not thinking of?
Thanks for your help!
N
N
