zorro
Hi all,
The simplest form of the "dilemma" of no single solution is what we get with Vdc=0 in the original post and merging the two capacitors into a single one. It is a "circuit" consisting of a single capacitor; the terminal connected to ground is the reference node.
If we consider an ideal (lossless) capacitor, it can hold any voltage indefinitely.
The circuit has only one node (other than the reference).
Lossless means in this case that parallel conductance from the single node (to the reference) is zero.
The dual of this "circuit" is an ideal (lossless) short circuited inductor.
The current across it continues to circulate indefinitely.
The circuit has only one mesh.
Lossless means in this case that series resistance in the single mesh is zero.
A useful point of view is that these "circuits" have an "initial" condition that does not evolve in time towards a steady state of zero stored energy because there are no losses able to dissipate it.
The single-C circuit holds a nonzero voltage if (and only if) there is a nonzero net electric charge in its single node.
Analogously, In the original circuit (with Vdc and 2 identical ideal capacitors) the solution with Vdc/2 on each of the capacitors assumes that there is no net charge in the node connecting them.
For all other solutions (see LvW's post #8 and FvM's post #16), there is a net charge in that node.
Regards
Z
Regards
Z
