babatundeawe
Full Member level 5
- Joined
- Apr 12, 2007
- Messages
- 244
- Helped
- 16
- Reputation
- 32
- Reaction score
- 12
- Trophy points
- 1,298
- Location
- Nigeria
- Activity points
- 2,738
from the diagram you do not show where your drive signal for the hbridge driver is comming from. can u please review. from the diagram in post 2 you could see that the 556 was also fed back with the voltage from the first conversion. but from my understanding of the circuit in post 2 one of the first 555 is use as an astable and the other a monostable.
load vltage dropping can also be caused by the size of the transformer which in your cas is the hf. if they are not properly sized.
hope this helps
hope this helps
