GOWRISHANKARSL
Newbie level 5
What will happen if we give voltage as input to the i-v converter.Does it works?if it works means kindly say the output of that circuit also with respect to input voltage.
Simple methode which I used in the past:
Use a 1 OHM resistor, very small tolerance(0.001%). Any current that will flow will be similar to the same value in V.
Example: 500mV will be driven from 500mA. If you dont need a very high accuracy this simple resistor will be good for that.
Thomas
