Akanimo
Advanced Member level 3
- Joined
- Aug 30, 2016
- Messages
- 868
- Helped
- 146
- Reputation
- 292
- Reaction score
- 169
- Trophy points
- 1,323
- Activity points
- 7,325
Simulation result: requirement met.
That correction was great.
[b]CODE VHDL[/b]
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL;
ENTITY UP_3_DOWN_2 IS
PORT(clk, rst : IN STD_LOGIC := '0';
cnt : BUFFER INTEGER RANGE 0 TO 9 := 0);
END ENTITY UP_3_DOWN_2;
ARCHITECTURE OP OF UP_3_DOWN_2 IS
SIGNAL cnt_int : INTEGER RANGE 0 TO 9 := 0;
SIGNAL up : STD_LOGIC := '1';
BEGIN
process(clk, rst)
begin
if rst = '0' then
cnt <= 0;
cnt_int <= 0;
up <= '0';
elsif clk = '1' and clk'event then
cnt_int <= cnt_int + 1;
if up = '1' then
if cnt_int = 2 then
cnt_int <= 0;
up <= '0';
end if;
else -- down
if cnt_int = 1 then
cnt_int <= 0;
up <= '1'; [B]-- FvM's correction[/B]
end if;
end if;
if up = '1' then
cnt <= cnt + 1;
else
cnt <= cnt - 1;
end if;
end if;
end process;
END ARCHITECTURE;
FvM, thanks for pointing to this rule in this scenario. That was helpful.What do you mean with conflict? According to VHDL rules the last assignment (reset) is executed.
