c_mitra
Advanced Member level 6
Its interesting though, if the turns stay the same, and the required back EMF stays the same, the flux must be the same too. It just takes a massive amount of current to do it when you remove the core.
Back emf is not related to the flux; it is directly related to the derivative of the flux (rate of change of flux).
Flux change of 1-11 and 101-111 (same units) in the same interval will produce the same back emf.
Effective permeability will change both the flux and the rate of change of flux by the same factor.
