MuhammadAnas25
Newbie level 5
Can any one make a 100v to 12v dc-dc converter
Can you please explain me how i am a new in electronicsCertainly - all you need is a 1M resistor and a 12V Zener diode.
Hello I am new in electronics can you suggest to me the best circuit to convert 100V to 12v my circuit needs 12v 1A current and I have an Electric forklift which gives 95v output which I need to convert to 12v for my circuitCertainly - all you need is a 1M resistor and a 12V Zener diode.
1) 95V-100V DCSome questions :
1) 95V is DC or AC ?
2) The 12V, what is its load ?
3) What is allowable range / tolerance of 12V supply output V ?
4) Minimum load current that will always exist ?
5) Does 95V supply have load dump transient V generation issues ?
6) 95V supply, what is its absolute min / max V ?
7) What is ambient temperature range the Fork Lift has to operate in ?
Regards, Dana.
Thanks, DanaSo basically you have to drop, worst case, 100 - 12 V = 88 V.
So pick a 30V DC DC module to gen the 12V, then drop the rest arcoss
a series of zeners.
So lets pick a DC DC thats 80% efficient, output load = 12W, so input power =
12 / .8 = 1.5W. So Input current = 1.5 / 30 = 50 mA.
So we have to drop 100 to 30 with a current of 50 mA. So Pz = 70 x .03 = 2.1W
So use a 5W (margin over 2.1WW) = ~ 70V zener.
Zener must have a heat sink.
DC - DC module : https://www.banggood.com/LM2596-DC-...-p-1005123.html?cur_warehouse=CN&rmmds=search
You can trade off input V to DC to DC with zener ratings, just make sure you always use margin
worst case for design, say 50%. Asd you raise Vin of DC to DC the Pz drops.
Regards, Dana.
Can you please suggest the zener diode it would be very helpful for me as I need to drop 30V dc only from 100V dc for my converterYou have to go thru the calculations, to get at Zener power just as I showed you.
Regards, Dana.
So we have to drop 100 to 30 with a current of 500 mA. So Pz = 70 x .5 =35W
So use a 50W (margin over 35W) , 70V zener (68V seems closest).
Hey, Dana thank you for your reply actually this zener diode is not available in my country can you please suggest me an alternative circuit to drop 100VDC to 70VDC whose components are easily available?@KerimF
Thanks for picking this up.
@MuhammadAnas
So in post # 7 this :
Should be changed to this :
Regards, Dana.
--- Updated ---
Notes on heatsink design for Zener :
https://www.digikey.com/Site/Global/Layouts/DownloadPdf.ashx?pdfUrl=F51974C9A6D544F1A7D8F119514B67FF
Heatsink Calculations – Renewable Energy Innovation
www.re-innovation.co.uk
Regards, Dana.
