Convert Protel99 to pdf
zibby
Junior Member level 1
protel 99
I have some designs downloaded from Willem.org in protel format,
and wonder if someone woulb be able to make them pdf files.
It's few adapters for willem programmer (schematic and pcb)
I'll upload files only if someone can convert it.
Thanks for your help.
Zibby.
print from pcb in protel 99
You directly upload it in pdf format if you download the free pdf creator: PDFCRETAOR.
CD:)
converter to protel 99
Acrobat distiller -- Print project / save as files
protel 99 pdf
Set the virtual printer "acrobat distiller" as your printer. print the file. the file will be displayed in Acrobat or acrobat reader.(Acrobat 5 or Acrobat 6 needed.)
protel99se pcb to pdf file
I know how to make pdf files (have distiller) but I don't have Protel
I use Eagle PCB.
Attached are files in protel
Thanks.
protel 99 file
you can use FinePrint PDFFactory
reading protel99 files
I converted one in PDF format.
converting protel 99 files
Can you convert the other file(s)?
Thanks.
reading protel 99 files
You can install Adobe Acrobat (NOT reader version),then Pirnt it in protel,select print to dill.. printer.
protel 99 export pdf
I don't have or use Protel. So that's why I asked someone to convert those files to pdf, so I can recreate them in EGALE PCB.
I know how to make pdf files, but if I don't have Protel (99SE or DXP)
than there is no way to open those files, isn't it.
bitbaby, Please read original message
Thanks.
convert protel 99 to pdf
thanks man but what is the version of this PCB?
protel 99 se viewer download free
Please specify both schematic and pcb drawings need to be converted? or Schematic alone?
Nishal
