karthickb3e
Hi all,
I am using MSP430G2152 controller for my project. I am using the 8MHz calibrated clock. At power up, the controller not works, but the voltage at supply pin and reset pin is at correct level. This problem occurs repeatedly while slowly varying (I am using variable power supply at input side (0 – 30)V dc.. there is 3.3 V regulator in the power supply circuit) the input voltage at power supply… Please give suggestions to solve my problem….
I checked the same program(but timing values changed as to the 1Mhz Clock frequency) in 1MHz calibrated clock, this problem not occurs.. But I need higher speed of operation(on 1Mhz Clock frequency) so suggest solving the problem…….
