lesdox
Hello everybody.I have to implement the in house circuit cc-ih circuit which is an energy harvester circuit using simscape electrical. The description of the circuit can be found on page 7 of the pdf at Finite element-based assessment of energy harvesting in composite beams with piezoelectric transducers:
As you can see it has a detailed analysis of it, and also its diagram. My simscape implementation so far looks like this:
obviously the control logic needed for the mosfet to turn on/off is missing, cause this is where i am having the trouble. firstly , as the pdf does not metnion the two threshold voltages i should use, what values would you guys suggest. secondly, lets say we know what values we should use, how should i procceed from there. i tried using relation operator with constant blocks to represent the logic but it didnt work since the voltage of the capacitor was coming fully wrong. i also tried the relay block and didnt work either. if any has any idea would be REALLY helpfull.!
