jackjtchan
Junior Member level 3
Common-Mode feedback tutorial
I think the R and C generate both a pole 1/R(C+Cg) and a zero 1/RC, where Cg is the gate capacitance of the input transistor of the CMFB amplifier.daisyinfall said:In my opinion,the R and C generated a zero,not a pole.
yyliang said:I am designing a op amp,the first stage is differential output and the second stage is single-end output,need I add a CMFB circuits to the op amp for the first stage?
Mistico_Pereyra said:joskin said:In the full differential opamp,the common mode signal detector is formed with two resistors in parallel with two capacitors in most cases.
What's the function of the capacitors?
What will happen without the capacitors?
You can learn about this in the nex file:
