pcdata76
Junior Member level 1
- Joined
- Oct 17, 2015
- Messages
- 18
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Germany
- Activity points
- 1,515
I solved the first problem. By using the Capacitance-ESR meter that i've built. i removed and measured all electrolytic caps except the ones at tuner section. Some of them, especially few caps in power supply and one cap in horizontal deflection are way out of tolerance in means of ESR (i mean instead of some 0.x ohms, i measured 1x.x ohms) I replaced them all with new ones by selecting the most low-ESR one in my vault. So in total, i replaced around 20 caps including the slight off-tolerance ones. I powered the TV on but nothing changed in means of retrace lines except some change in geometry possibly caused by the replacement of faulty cap at deflection. Then, i removed EEPROM from the board and put an IC-socket instead. I programmed another new EEPROM using the .bin file which i've found from internet and put it on TV board. I powered the TV on and hopefully, retrace lines were away! Raster was too overscanned due to the default settings on eeprom but i changed it quickly by displaying a pattern on TV using service menu. Now, retrace line problem looks like to be solved.
The second problem, i was hoping that this one should also be solved thanks to the change of all failed electrolytics especially in power supply section, but unfortunately nothing changed. I pushed and distorted the board using a plastic rod in case of a possible cold solder junction but nothing observed. I also re-route the cables inside of the tv to keep them avay enough from deflection yoke and FBT but this one also doesnt changed anything.
Since noisy lines have a frequency of 50 (or 100 hz) i still suspect from power supply. I'll change the main rectifier bridge now in case of a leakage. I measured D601, the 2nd and only diode directly connected to the 50 hz mains together with bridge rectifier, but it was ok (a leakage around 2 microamperes which is OK, and a forward voltage within limits) This problem is more annoying than the retrace lines because they are not stationary at the modes with 60Hz vertical scan rate, which are mostly used on this tv.
