[SOLVED] CLK stay 0 when VCS&Verdi simulation
Jordon
Shanghai, China
Hi, I'm tring to simulate a simple design adder, but when simulation, the CLK signal stay 0 so that no wave for me debug. Can you help me?
My codes and script are shown as below,
Adder module:
module top(input wire clk, input wire [27:0] io_in, output wire [27:0] io_out, io_oeb);
    wire rst = io_in[0];
    reg [15:0] ctr;
    always @(posedge clk)
        if (rst)
            ctr <= 0;
        else
            ctr <= ctr + 1'b1;
    assign io_out = {10'h123, ctr, rst, 1'b0}; // pass thru reset for debugging
    assign io_oeb = 28'b1;
endmodule
testbench:
module adder_tb;
    reg [27:0] O_top = 0;
    reg CLK;
    wire [27:0] I_top_gold, oeb_gold, T_top_gold;
    top dut_i (
        .clk(CLK),
        .io_out(I_top_gold),
        .io_oeb(oeb_gold),
        .io_in(O_top)
    assign T_top_gold = ~oeb_gold;
    //always #50 CLK = (CLK === 1'b0);
    always #50 CLK = ~CLK ;
    integer i;
    reg have_errors = 1'b0;
    initial begin
        CLK = 0;
        repeat (100) @(posedge CLK);
        O_top = 28'b1; // reset
    $display("in_in = 0x%X, gold = 0x%X, gold = 0x%X", O_top, I_top_gold, T_top_gold);
        repeat (50) @(posedge CLK);
        O_top = 28'b0;
        for (i = 0; i < 100; i = i + 1) begin
            @(negedge CLK);
        end
    $fsdbDumpfile("adder_tb.fsdb");
    $fsdbDumpvars(0,adder_tb);
    $fsdbDumpSVA();
    $fsdbDumpMDA();
    $vcdpluson;
    $vcdplusmemon;
        if (have_errors)
            $fatal;
        else
            $finish;
    end
endmodule
module clk_buf(input A, output X);
assign X = A;
endmodule
Makefile:
all:clean comp sim
OUTPUT = efpga_presim
PDK_Path = /opt/eda/PDK/....../tcbn28hpcplusbwp30p140_110a
#     -sverilog ${PDK_Path}/tcbn28hpcplusbwp30p140.v
comp:
    vcs -R -full64 +v2k \
    -timescale=1ps/1ps \
    -sverilog +vcs+lic+wait -debug_access+all -kdb \
    /verilog_codes/*.v \
    +define+sdfannot+fsdb \
    +neg_tchk \
    -l com.log
sim:
    ./simv -l sim.log
# debug:
#     dve -full64 -vpd vcdplus.vpd &
verdi:
    verdi -f /verilog_codes/*.v \
    -ssf adder_tb.fsdb  -nolog
clean:
    rm -rf csrc DVEfiles *.vpd simv simv* ucli.key vc_hdrs.h urg* *.log *.dump *profile*
When i type ` make all , get into verdi, there no wave in CLK, i mean there is CLK signal, but it stays 0, like:
what should i do fo that?
you are not driving the clk
this line of code seems to be the problem. I think you got the delayed assignment wrong. write a simple always block where you set the clock to 1, wait 50, set it to 0. three separate lines. it will work.
Thanks for your reply, the clock is indeed wrong. I found the solution when put the
initila begin
    $fsdbDumpSVA();
    $fsdbDumpMDA();
    $vcdpluson;
    $vcdplusmemon;
end
behind the first "initial" block after tring to modify the clock .
