maark6000
Member level 5
so below is a Class AB amp with a current mirror provided by diodes. I simply cannot get this circuit to work. I initially had the pnp in backwards, I forgot they flip it upside down, but now it's in right.
my input is a 1 kHz sine wave, 10v pp. my output is a capped sine wave, 1.4 v pp. it seems the circuit works until each diode reaches it's bias voltage, and then I don't know where the rest of the sine wave goes. could this be a grounding problem?
My power supply has a negative output, a ground, and a positive output. As such, I am hooking the negative to the -Vcc rail, the positive to the +Vcc rail, and not using the ground on the power supply. The AC signal has it's own ground rail, and the positive lead is at the input. Is that right?
Thanks.
Thanks.
