KlausST
Advanced Member level 7
- Joined
- Apr 17, 2014
- Messages
- 26,326
- Helped
- 4,926
- Reputation
- 9,875
- Reaction score
- 5,802
- Trophy points
- 1,393
- Activity points
- 177,265
post#15
I don´t recommend this.
But if you use a true filter then the additional ADC driver won´t harm the anti aliasing function.
An anti aliasing filter is not related to "noise" in first place.
For sure you may call all unwanted frequencies as noise.
I like the definition of noise as "random" frequencies. When we follow this definition then coupled switching "noise" from an SMPS is "not noise" but a known fixed frequency.
The same applies for overtones caused by distortion of your (wanted) signal.
The noise caused by the ADC drier should be negegible.
So the ADC driver needs to detect (feedback) error at it´s output and needs to be fast enough to correct it.
--> for this you need a fast amplifier (much faster than the signal frequency. Indeed it does not depend on signal frequency but on the expected settling time). And it needs to provide low output impedance at high frequencies.
The requirements for the ADC driver are given in the ADC datasheet.
I recommend to read some application notes about driving ADCs.
Klaus
post#15
If he accepts an ADC driver, then use it. Basically it still is an amplifier, but if a differnt name solves the problem.. ;-)if you remember my team leader want to avoide chaining analog amplifiers
Do I understand this correctly? You use the cutoff of an amplifer as anti-aliasing filter.so I think I will loose the advantages of the anti-aliasing filter for filtering in my analogue readout circuitry
AN ADC driver has to be fast to drive the ADC input. Especially successive approximation ADCs often use a capacitor at the input. If used as HOLD capacitor, then the input is switched ON/OFF to the capacitor. This causes transients and the ADC driver needs to handle it (low ringing) and needs to set the ADC input precisely to a stable value within a short time.if our analog front ends with amplifier havieng wide bandwidth, what will be the advantague of haveing the filter before.
Klaus
