FriedPope
Newbie level 3
- Joined
- Feb 10, 2005
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Durango, Colorado
- Activity points
- 38
This ones got me stumped...
Background: I need two outputs activated by two switches, simple right? Here’s the catch. I want to use both switches to activate one of the outputs. If switch 1 is closed and THEN switch 2 is closed, output A should be high. If switch 2 is closed and THEN switch 1 is closed, output B should be high. There needs to be a time out to reset the switches after a set time and possibly an output C triggered when both inputs are held high at the same time.
Ideas: *Clocked Flip-Flips
*Not much else
I hope this helps some other designers out there. I’d love to hear any input you might have.
*Not much else
