The values don't make much sense, however. If the input to the circuit is AC, then a reasonable filter capacitor value for 1 A output current would be several 1000 µF. Output filtering with 100 µF is very unusual, it may be possibly required for pulsating loads.the purpose of the first is to feed the ip AC to the LM regulator and the second 101 uF is for filtering the op
They look like been arbitrary choosen. They may be still reasonable under special conditions, but not as a general suggestion.So the design has some errors in it sir FvM.
U can see the Reverse Bias (RB) i-v curve of zener diode: The (reverse) voltage across the zener diode remains approximately constant over a wide current range (i.e. voltage constant for changing current). Keep in mind the voltage referred is usually the voltage across the device(here zener diode); it may be different than applied voltage & the current referred is the current through the device.tanx friend another one
how zener diodes work and i so some regulated circuit use these diodes what are the use of it
Cap Cin is necessary when regulator is not close to power supply filter circuit; the inductance of connecting wire (wire b/w filter & regulator) may produce oscillations. Bypass cap Cout used to improve the transient response of regulator and it ensures ac stability.why capacitors use in voltage regulator circuit what is the use of it
Typical values for either bypass capacitor are from 0.1 to 1uF. the data sheet of 78xx series suggests 0.22uF for Cin and 0.1uF for Cout...IMHO you should refer to the capacitor suggestions in the datasheet...
