capacitor use problems
Nipuna56
Full Member level 1
why capacitors use in voltage regulator circuit what is the use of it
They are also used along with Zener diodes for more rectification of AC signal
if we use DC power supply for our project still need that cap?
No In DC supply the cap is open circuited so here they are used to generate OPEN CKTS that let current to flow through the parallel path without any loss
if i don't use caps what can be seen
or what wrongs that can appears
In the case of DC supplies consider this if the supply is distributed parallelly and if you don't want current to flow through one path then we use a capacitor as the reactance of the cap is almost infinity in case of DC supplies so we go for it
In AC ckts they have many purposes the Filter the ripples by consequetive charging and discharging
in resonant ckts they are used to tune the frequency and many more
if i don't use caps some times voltage can varying?
In a rectifier circuit if you don't use a Capacitor you will get pulsating DC cycles and so the op voltage will vary
tanx friend another one
how zener diodes work and i so some regulated circuit use these diodes what are the use of it
capacitor is a filter and even after filtering there is a small amount of ripple in the op this is removed by the ZENER diode it almost completely removes the AC component from the signal
we can get good regulated output using higher value capasitor
(if we use 100uf we can get better out put )
is that correct?
that depends not only on the capacitor but also the time constant of the capacitor in use that means the resistance and the capacitance needs to be high
higher the capacitance more time takes for the cap to completely discharge there by the rectification is more in the case of higher order caps
i have seen in some regulated circuit two 100uf and two 0.1uf using near 78xx regulator please explain this
