strahd_von_zarovich
Full Member level 2
- Joined
- Sep 25, 2015
- Messages
- 120
- Helped
- 1
- Reputation
- 2
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 2,480
Hi everyone,
I am trying to find the IC in the picture. It is used in a capacitive accelerometer module. Sensor part consists of 2 capacitors, and their common plate is ground. When the module is under acceleration one capacitance decreases while the other one increases. Capacitors' plates(not the common ground one) are connected directly to the IC and I know IC has internal excitation source which has a frequency of ~450kHz~500kHz. And most probably IC's output is analog signal.
Have you seen such an IC? Either it compares 2 capacitances, or it has 2 inputs and 2 outputs I don't know. In addition, it is fairly sensitive device which can measure pF changes.
Device marking on IC was intentionally erased.
Thanks in advance.
Thanks in advance.
