Can't compile a module. VVP stucks.
Xenon02
Full Member level 3
Hello !
I do have a problem with compiling my code :
module alu(i_a, i_b , i_oper, o_y, o_status, i_rsn, i_clk);
parameter BITS = 4;
parameter OPER = 3;
input logic signed [BITS - 1:0] i_a, i_b;
input logic [OPER-2:0] i_oper;
input logic i_clk;
input logic i_rsn;
output logic signed [BITS - 1:0] o_y;
output logic [3:0] o_status;
logic [BITS - 1:0] o_y_mux;
logic [BITS - 1:0] o_y_1;
logic [BITS - 1:0] o_y_2;
logic [BITS - 1:0] o_y_3;
logic [BITS - 1:0] o_y_4;
logic [3:0] o_status_mux;
logic [3:0] o_status_1;
logic [3:0] o_status_2;
logic [3:0] o_status_3;
logic [3:0] o_status_4;
ashift_example1 #(.BITS(BITS)) case1 (.i_a(i_a), .i_b(i_b), .o_arith_left(o_y_1), .o_error(o_status_1));
U2_to_ZM #(.BITS(BITS)) case2 (.i_a(i_a), .o_zm(o_y_2), .o_status(o_status_2));
porownanie #(.BITS(BITS)) case3 (.i_a(i_a), .i_b(i_b), .o_smaller(o_y_3), .o_error(o_status_3));
replace #(.BITS(BITS)) case4 (.i_a(i_a), .i_b(i_b), .o_replaced(o_y_4), .o_error(o_status_4));
always_comb
begin
{o_y_mux, o_status_mux} = '0;
case (i_oper)
2'b00 : o_y_mux = o_y_1;
2'b01 : o_y_mux = o_y_2;
2'b10 : o_y_mux = o_y_3;
2'b11 : o_y_mux = o_y_4;
default : o_y_mux = '0;
endcase
case (i_oper)
2'b00 : o_status_mux = o_status_1;
2'b01 : o_status_mux = o_status_2;
2'b10 : o_status_mux = o_status_3;
2'b11 : o_status_mux = o_status_4;
default : o_status_mux = '0;
endcase
end
always_ff @(posedge i_clk)
begin
if(i_rsn == 1)
begin
o_y <= o_y_mux;
o_status <= o_status_mux;
end
else
begin
o_y <= '0;
o_status <= '0;
end
end
endmodule
This is the code for the module
module ashift_example1(i_a, i_b, o_arith_left, o_error);
parameter BITS = 4;
input logic signed [BITS-1:0] i_a, i_b;
output logic signed [BITS-1:0] o_arith_left;
output logic [3:0] o_error;
integer x;
always_comb
begin
x = 0;
o_arith_left = '0;
o_error = '0;
if(i_b >= 0)
begin
o_arith_left = i_a <<< i_b;
if(i_a < 0)
begin
o_arith_left[BITS-1] = 'd1;
end
else
begin
o_arith_left[BITS-1] = 'd0;
end
end
else
begin
o_error[0] = 1;
o_arith_left = 'x;
end
for (int i = 0; i<BITS;i++)
begin
if(o_arith_left == 1)
begin
x = x+1;
end
end
if (x % 2 == 0 && o_arith_left != '0)
begin
o_error[1] = 1;
end
if(o_arith_left == '1)
begin
o_error[2] = 1;
end
end
endmodule
module U2_to_ZM (i_a , o_zm, o_status);
parameter BITS = 4;
input logic signed [BITS-1:0] i_a;
output logic signed [BITS-1:0] o_zm;
logic signed [BITS-1:0] one;
integer x;
always_comb
begin
x = 0;
one = i_a;
o_status = '0;
if(i_a < 0)
begin
for (int i = 0; i<BITS-1; i++)
begin
one = ~i_a;
end
if(one == '1)
begin
o_status[3] = 1;
o_status[0] = 1;
o_zm = 'x;
end
else
begin
o_zm = one + 1;
end
end
else
begin
o_zm = one;
end
begin
if(o_zm == 1)
begin
x = x + 1;
end
end
if (x % 2 == 0 && o_zm != '0)
begin
o_status[1] = 1;
end
if (o_zm == '1)
begin
o_status[2] = 1;
end
end
endmodule
module porownanie(i_a, i_b, o_smaller, o_error);
parameter BITS = 4;
output logic signed [BITS-1:0] o_smaller;
always_comb
begin
o_error = '0;
o_smaller = '0;
if(i_a<=i_b)
begin
o_smaller = 'd1;
end
else
begin
o_smaller = '0;
end
if(o_smaller == '1)
begin
o_error[2] = 1;
end
end
endmodule
module replace(i_a, i_b, o_replaced, o_error);
parameter BITS = 4;
output logic signed [BITS-1:0] o_replaced;
integer x;
integer i;
always_comb
begin
x = 0;
i = 0;
o_replaced = '0;
o_error = '0;
if(i_b < 0 || i_b > BITS)
begin
o_error[0] = 1;
o_replaced = 'x;
end
else
begin
i = i_b;
o_replaced = i_a;
o_replaced = 1;
end
begin
if(o_replaced == 1)
begin
x = x+1;
end
end
if (x % 2 == 0 && o_replaced != '0)
begin
o_error[1] = 1;
end
if (o_replaced == '1)
begin
o_error[2] = 1;
end
end
endmodule
And here are the modules that are in the multiplexer
here is the testbech :
`timescale 1ns/1ps
module test_alu;
parameter BITS = 4;
parameter OPER = 3;
logic i_rsn;
logic i_clk;
logic signed [BITS - 1:0] o_y_rtl;
logic [3:0] o_status_rtl;
alu #(.BITS(BITS), .OPER(OPER)) alu (.i_a(i_a), .i_b(i_b), .i_oper(i_oper), .o_y(o_y), .o_status(o_status), .i_rsn(i_rsn), .i_clk(i_clk));
//exe_unit_38_rtl alu_rtl (.i_a(i_a), .i_b(i_b), .i_oper(i_oper), .o_y(o_y_rtl), .o_status(o_status_rtl), .i_rsn(i_rsn), .i_clk(i_clk));
initial
begin
$dumpfile("alu.vcd");
$dumpvars(0,test_alu);
i_rsn = 1;
i_clk = 0;
i_oper = 2;
i_a = '0;
i_b = '0;
#1
i_clk = 1;
i_oper = 1;
i_a[3] = 1;
#1
i_clk = 0;
i_oper = 3;
i_b[3] = 0;
i_a[3] = 0;
i_a[2] = 1;
i_a[0] = 0;
#1
i_clk = 1;
i_oper = 0;
i_a[0] = 0;
i_b[1] = 1;
i_a[3] = 1;
#1
$finish;
end
endmodule
I don't know where is the error in it. when I do my vvp this happens :
Don't know what to do ...
