cannot implement UART in ATMEGA16.
shashankshanky
Newbie level 3
hi all,
i want to receive the data from the hyperterminal and set PORT A high. however no data was transferred. i also tried receiving the data from the micro-controller. Even this was not working.
Later, i tried to simulate the same using the protheus designing software. still no response. tired of these, i tried simulating the sample code available in the data sheet. i even set the required bits to zero for asynchronous operation. all my efforts are wasted. i dont know where i am going wrong. please help me solve my problem .
c code:
#include<avr/io.h>
#define FOSC 1843200// Clock Speed
#define BAUD 9600
#define MYUBRR FOSC/16/BAUD-1
void USART_Init( unsigned int ubrr)
/* Set baud rate */
UBRRH = (unsigned char)(ubrr>>8);
UBRRL = (unsigned char)ubrr;
/* Enable receiver and transmitter */
UCSRB = (1<<RXEN)|(1<<TXEN);
/* Set frame format: 8data, 2stop bit */
UCSRC = (0<<URSEL)|(0<<USBS)|(3<<UCSZ0);
unsigned char USART_Receive( void )
/* Wait for data to be received */
while ( !(UCSRA & (1<<RXC)) )
/* Get and return received data from buffer */
return UDR;
void USART_Transmit( unsigned char data )
/* Wait for empty transmit buffer */
while ( !( UCSRA & (1<<UDRE)) )
/* Put data into buffer, sends the data */
UDR = data;
int main( void )
DDRA=0B11111111;
int i;
unsigned char recdata';
USART_Init ( MYUBRR );
for(i=0;i<10;i++)
recdata=USART_Receive();
PORTA=0B11111111;
i tried everything. only problem i get is during the data (transmission or receiving). neither data is being received nor transmitted .I tried simulating everything in proteus designing software. still no solution. please help me
first try some most usual frequency such as 8MHZ or something like that. Secondly try the communication to simple 8bit no parity 1 bit for stopping.
