Can I use a 1N4148 diode like a 0.5V reference???
crono376
Newbie level 5
Newbie level 5
using 1n4148 as reference voltage
I need to do a 0.5V reference. I planing to use an 1N4148 in serie with a 10K resistor, and the 0.5V throgh diode buffered by a OPAMP.
I need to known the presicion of this kind of configuration.
Wich is the better way to do that?
Thanks in advance
0.5v reference
The forward drop will vary by about -2mV/°C (T+) and +2mV/°C (T-)
1n4148 voltage regulator
It is not a good idea to use 1N4148 diode as a 0.5V reference ..
Employ any compensated voltage regulator, such as 78L05 or similar, divide its voltage by 10 (using 2 resistors) and, buffer it (if required) using an opamp such as CA3140, LM358 (or similar) to ensure voltage source properties at the output ..
Regards,
IanP
I would not be tempted to use a in 4148 or any other power/signal diode as a voltage reference . Use a dedicated reference component or go the way Ianp described.
A lot will depend on just how good you require your reference voltage to be . Go with the dedicated reference component.
Barry bear
Only if you are able to keep it at the same temperature. But it's easier and cheaper to use dedicated voltage references.
Use precision zener diod with more voltage and resistor divider (tolerance 0.1%).
TL431(2.5 Volt Bandgap voltage reference)+voltage devider!
BEST!
Use an LM385-1.2 from National. It's a 1.2V reference. Divide down the voltage with precision resistors, preferrably a resistor network, so they track over temperature.
using LM4051-adj low temp. coefficient shunt reference....
