Calculation of phase and Amplitude of an IF signal
yasine79
germany
Hello all,
when i have an IFsignal, i know the method to calculate the Amplitude and the phase. First the I and Q componenent should be calculated,this is achieved with downconverting the IF signal digitaly DDC.
Amplitude=sqrt(I^2+Q^2). phase=atan2(Q/I).
my quuestion is: is it possible to calculate the amplitude and the Phase of the IF signal with FFT?
what are the adventages of the FFT in this case?
Thank you
Yes with an FFT you can calculate phase and ampltude.
The advantage of the fft is that you calculate relatively fast the real and imaginary part of a lot of frequencies.
If the desired frequency is known i'd prefer dft here.
thanks for ur reply. I wonder why in the literature the most discussed topic for calculating the amp and phase from an IF signal is the calculation of I and Q. Do u know any literature discussing this topic with DFT for heterodyne (or homodyne) receiver?
thank u
there are always quadrature recivers because in examples survillence radars information that u gain from dtf - frequency and amplitude - is not enought - signal has to match some pattern - ex. pulse width ( rising, falling time).
