patan.gova
Full Member level 3
I didn't get this.
You mean if the coupling capacitor is not used then the low frequency components gets into the signal.But there was a HP filter prior to the LP filter won't the HP filter remove the lower freq if so, how the lower freq will be added again in the LP filter(If coupling capacitor is not used).All coupling capacitors increase the cutoff frequency so they all must be considered.
