[PIC] C# USB transmit error
Please zip and post the original untouched VC# project and mention which version of Visual Studio has to be used to open the file. I tried opening in VS 2008, VS 2010, VS 2012, VS 2013 and VS 2015 but they don't show the Windows Form of the project.
Edit: It opened in VS 2010.
Make this small change and see if it works.
Code C - [expand]
8
9
10
11
12
private void btnReceive_Click(object sender, EventArgs e)
            int i=0, j=0, k=0;
            byte[] data = new byte [64];
            byte[] str = new byte [64];
            data = dev.Receive();
            if (data != null)
                txtReceive.Text = System.Text.Encoding.ASCII.GetString(data);
It worked for me. I will modify the mikroC project file and post it here. I will also modify the VC# app so that it displays the data as soon as it receives it.
  • PIC USB C#.rar
Dear Sir,
I mean that at the second time when I sent the information to MCU, the data including that information VC# received. Like this
After VC# app receives data and displays it try to clear the buffer (data buffer) used for USB HID reception. Also clear the buffers used in mikroC code after each USB HID communication.
Dear Sir,
I will try it later. Today and tomorrow I have important examinations :bang:.
I tried to use Zedgraph software to plot signal received from MCU. But I think my working exist some limitations.
It is have a problem when I sent data at the second time Sir.
For example, the first time I send "BiNa" and LCD displayed perfectly on screen but the second time when I send "1" so LCD displays "1iNa" that mean the readbuff[] is still contain the old values.
In MikroC, LCD before printing a new value to LCD clear the LCD line by using
LCD_Out(1,1,"                ")
It is not work in my case.
I don't still fix it Sir.
I MikroC I use this
Lcd_Cmd(_LCD_CLEAR);
   readbuff[0] = 0;
   str[0] = 0;
In VC# I use these code
EnviarDadosUSB(DataWrite);    //Send to Microcontroller the USB Buffer
            DataWrite[63] = (byte)0;    ////any byte Data (0 ~ 63)
You are not clearing all the elements of the buffers. Use a loop and clear the complete buffers.
Everything work well in the simulation file (send data from my PC to PIC18F4550) but when I try to connect RFID Reader when MCU C8051F430 interface with USB block. I cannot send any data although my firmware can detect this USB device.
