Anna Conda
Banned
- Joined
- Oct 13, 2011
- Messages
- 159
- Helped
- 48
- Reputation
- 292
- Reaction score
- 140
- Trophy points
- 1,323
- Location
- Melbourne
- Activity points
- 0
There is one thing about the IR2110 series to be aware of: if you have a pretty loose layout and poor decoupling of the power stage, then, with an inductive load, when the upper switch turns off the midpoint can swing to below gnd for a short while, this has the effect of bringing into play the intrinsic internal diodes in the 2110 chip and can be destructive and or detrimental to operation, buffering will not necessarily solve this problem as it is the tie point in the middle of the power xtor pair that still connects to the IC, this is possibly why GDT's help the operation so much, as it cuts this connection and the IC (2110) is now unaffected by the source of the upper devices going several volts below gnd.
You see on some datasheets for hi/lo 1/2 bridge drivers, a voltage limit spec for this and sometimes a duration or dv/dt spec as well.
