- Joined
- Jan 22, 2008
- Messages
- 53,704
- Helped
- 14,811
- Reputation
- 29,919
- Reaction score
- 14,441
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 303,619
FET in buck converter
It' difficult to judge the meaning of the shown waveform for high voltage operation without knowing the absolute commutated current. Also the actual dId/dt would be an interesting parameter.
Do I assume right, that the waveform has been acquired with the 10n/2R2 snubber in place. In this case, I get an commutating loop inductance of about 50 nH from the estimated resonace frequency. I think that a lower value should be achievable with TO220 transistor/diode and optimal layout.
On the other hand, the absolute voltage overshoot is proportional to circuit inductance and di/dt, not Ub. So it's not said, that it must be too high at nominal operation voltage.
From the -5V undershoot, which is apperently caused by the gate drive, I have some doubts about correct probe connection.
P.S.: Regarding saturation problem, with 0.44A*12 turn you get a H value of 75 A/m for the ungapped core, which means strong saturation. A few 10 µ airgap would avoid saturation, but also reduces the inductance to about 250 µH.
