jurc
Junior Member level 1
buck converter mosfet
Hi guys! I'm really desperate here; no matter what I do, my buck converter just keeps burning my FETs. Here's the story;
I have 230Vac input, then a bridge and a capacitor to get DC. Then I have a MOS-N-FET SPP20N60C3 which I drive with a gate driver via a transformer. I use PWM at 200kHz and 25% duty cycle. If I put a 100W bulb as a load, the circuit works perfectly, no problems whatsoever (circuit 1).
However, if I put a buck converter, the MOSFET gets destroyed (Rds = 0 and Rgs = 0) the second I turn on the PWM. To ilustrate, I plugin the 220V; the blub stays off. Then I start PWM and the thing goes to full power. (circuit 2)
I've tried using other MOSFETs (Infineon, Fairchild and ST), but the same thing happens. So I'm asking for ideas, why does this happen?
Jure
Added after 16 minutes:
BTW, this is the gate drive scheme that I'm using:
If I power the circuit with 30V, everything works perfectly; I get nice clean signals. At 320V however
Jure
Jure
Jure
