bfr96s running hot in RF amplifier
Reactions: neazoi
    neazoi
Thanks! I will try it when the components arrive and let you know. (It might take a few weeks).
I see that there is no base bias resistors, how is the base biased is the input signal is too low?
I have used ideal current source and ideal RF Choke.You should design a current source with 2-3 small signal transistor ( PTAT is preferable PTAT=Proportional To Absolute Temperature)
and Ferrite Beaded RFC. ( for instance from EPCOS ).I have given simplified principal circuit, the rest is on you..
For 100uH coil, this fits your requirements..
https://gr.mouser.com/ProductDetail...=sGAEpiMZZMv126LJFLh8y4rsEyIjbuvqfO4aSkwpCiQ=
Reactions: neazoi
    neazoi
I worry about the base choke and rest of the circuit. Shall I connect the current source there?
Can't I just use an ordinary voltage divider to bias the bases?
