tahir4awan
Full Member level 4
I am confused with the methods of battery charging. Lets take an example of 6v 4.5Ah lead acid battery. There are lots of different charging circuits from simpler to complex. But what is the standard way of charging these kinds of batteries in terms of current and voltage?
Some people say you cannot charge these batteries too early with high current you need hours with low current to charge them otherwise they will damage.
I searched in the books but never found anything about a standard rating of charging current and voltage method.
Another example I have bought a 2.8 KVA generator with a 12V lead acid battery you will be shocked that it is charge directly from 12VDC socket of the generator.Then man from which I bought this generator said do not charge more than an hour otherwise it will damage.
Here some people are making LED emergency lights with 36 to 40 LEDS using three 4V lead acid batteries ad they are charging them with nokia adapter.
So I make my question simple. How we calculate standard charging voltage, current and time of a battery?
