diarmuid
Full Member level 2
- Joined
- Aug 4, 2011
- Messages
- 143
- Helped
- 10
- Reputation
- 20
- Reaction score
- 9
- Trophy points
- 1,308
- Location
- Dublin, Ireland
- Activity points
- 2,429
Hello All,
Im putting together a 2 stage opamp. Cc and Cl are close enough that the RHP zero is affecting my stability.
Im opting to use the nulling resistor method to transform the RHP zero into a LHP zero. Never done this
before so have the following questions:
1.) Method uses a FET for Rz and not an actual resistor to generate Rz >> 1/gm? Is this because gm will vary less than R?
Is it also because a FET will use less area?
2.) Say Im using a FET. Should it be NMOS or PMOS? At a guess I would say PMOS due to its lower mobility and hence higher
impedance. Is my thinking correct here?
3.) When using a resistor for Rz it doesnt matter which side of Cc I place the resistor. Is this the same when using a FET?
I have only seen the FET placed at the LHS of the Cc. Is this to de-couple it from output voltage swings or something
like that?
4.) This method gives me a LHP zero which is great for stabilty. It does this without degrading my internal slew rate. Whats
the catch? Are there any downsides to this method i.e. generates thermal noise in the heart of the OTA or something?
If you have any general tips also about this method that would be great aswell.
Thanks a bunch,
Diarmuid
like that?
Thanks a bunch,
Diarmuid
