Barkhausen criteria in multivibrators
matbob
Full Member level 2
Full Member level 2
KERALA
My question may be absurd but can anyone tell me whether we can apply Barkhusen criteria for astable multivibrators? If it is possible,how?
No, you can't.
The reason is simple: The Barkhausen oscillation criterion is based on the loop gain of a circuit with feedback. Any "gain" by definition is a small signal parameter which is valid in the vicinity of an operating point located on a linear (or linearized) portion of the transfer curve.
Multivibrators are strong non-linear circuits which are switched between two extreme values.
(Hint: But I should add that by redesigning the feedback path of a multivibrator the whole circuit can work as a linear oscillator with sinusoidal signals by exploiting the frequency dependent gain of the opamp. But this is beyond your question. Anyhow, this is a very interesting property of the multivibrator structure)
