AXI arvalid signal issue
This is your investigation as you have the environment set with the slave instantiated.
changing ARADDR to 1 also does not work, I suspect the data is not actually written, but we have BVALID asserted and BRESP is ok
Can you not add-to-wave and investiage the slave internal signals? See if your data is getting latched after the address and write-data handshakes.
All I can say is that Xilinx AXI based cores might have bugs (they don't perform formal verification of their AXI based cores).
On another note, if there is an AXI Interconnect b/w the master and slave, then you might want to investigate the interface signals there.
Before blaming Xilinx IP - be very sure that your cores are functioning correctly.
This sounds very much like a slave issue. @promach. Telling us that it doesnt work helps no one, and we cannot help you. Unless you post your code, AND your test envirmnent, or a small example exhibiting the problems, there is nothing more we can do.
See https://gist.github.com/promach/251cbb3c9c9af401bf712dc4ccb76fb3#file-read_instructions-v
I have two AXi interfaces. I am only testing the one of the AXi interfaces.
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
`define LOOPBACK 1
module read_instructions(clk, reset,
            i_axi_awready, o_axi_awid, o_axi_awaddr, o_axi_awlen, o_axi_awsize, o_axi_awburst,
            o_axi_awlock, o_axi_awcache, o_axi_awprot, o_axi_awqos, o_axi_awvalid,
            i_axi_wready, o_axi_wdata, o_axi_wstrb, o_axi_wlast, o_axi_wvalid,
            i_axi_bid, i_axi_bresp, i_axi_bvalid, o_axi_bready,
            i_axi_arready, o_axi_arid, o_axi_araddr, o_axi_arlen, o_axi_arsize, o_axi_arburst,
            o_axi_arlock, o_axi_arcache, o_axi_arprot, o_axi_arqos, o_axi_arvalid,
            i_axi_rid, i_axi_rresp, i_axi_rvalid, i_axi_rdata, i_axi_rlast, o_axi_rready);
`ifdef FORMAL
    // AXI Address width (log wordsize) for DDR
    parameter C_AXI_ADDR_WIDTH = 9; // just for random test, need to change for actual neural network
    parameter C_AXI_DATA_WIDTH = 8; // related to AxSIZE
    parameter C_SIZE_OF_CACHE = 4; // for storing weights and biases parameters of neural network
`else
    parameter C_AXI_ADDR_WIDTH = 12; // just for random test, need to change for actual neural network
    parameter C_AXI_DATA_WIDTH = 128; // related to AxSIZE
    parameter C_SIZE_OF_CACHE = 64; // for storing weights and biases parameters of neural network
`endif
parameter C_AXI_ID_WIDTH    =   1;
localparam NUM_OF_BITS_PER_BYTES = 8;
localparam INCR_BURST_TYPE = 2'b01; // AxBURST[2:0] , see 'burst type' section in AXI spec
// AXI4 extends burst length support for the INCR burst type to 1 to 256 transfers.
// Support for all other burst types in AXI4 remains at 1 to 16 transfers.
// for wrapping bursts, the burst length must be 2, 4, 8, or 16
// a burst must not cross a 4KB address boundary
// early termination of bursts is not supported
localparam MAX_BURST_LENGTH = 255;
localparam BURST_SIZE_ENCODING_WIDTH = 3; // AxSIZE[2:0] , see 'burst size' section in AXI spec
localparam SUBWORD_SMALLEST_UNIT = 8; // smallest granularity in AXI protocol : 8 bit
localparam PROT_BITWIDTH = 3;
localparam QOS_BITWIDTH = 4;
localparam CACHE_BITWIDTH = 4;
input clk, reset;
// AXI write address channel signals
    input   wire            i_axi_awready; // Slave is ready to accept
    output  wire    [C_AXI_ID_WIDTH-1:0]    o_axi_awid; // Write ID
    output  reg [C_AXI_ADDR_WIDTH-1:0]  o_axi_awaddr;   // Write address
    output  wire    [$clog2(MAX_BURST_LENGTH)-1:0]      o_axi_awlen;    // Write Burst Length
    output  wire    [BURST_SIZE_ENCODING_WIDTH-1:0]     o_axi_awsize;   // Write Burst size
    output  wire    [1:0]       o_axi_awburst;  // Write Burst type
    output  wire    [0:0]       o_axi_awlock;   // Write lock type
    output  wire    [CACHE_BITWIDTH-1:0]        o_axi_awcache;  // Write Cache type
    output  wire    [PROT_BITWIDTH-1:0]     o_axi_awprot;   // Write Protection type
    output  wire    [QOS_BITWIDTH-1:0]      o_axi_awqos;    // Write Quality of Svc
    output  reg         o_axi_awvalid;  // Write address valid
// AXI write data channel signals
    input   wire            i_axi_wready;  // Write data ready
    output  reg [C_AXI_DATA_WIDTH-1:0]  o_axi_wdata;    // Write data
    output  reg [C_AXI_DATA_WIDTH/SUBWORD_SMALLEST_UNIT-1:0] o_axi_wstrb;   // Write strobes
    output  reg         o_axi_wlast;    // Last write transaction
    output  reg         o_axi_wvalid;   // Write valid
// AXI write response channel signals
/* verilator lint_off UNUSED */
    input wire [C_AXI_ID_WIDTH-1:0] i_axi_bid;  // Response ID
/* verilator lint_on UNUSED */
    input   wire [1:0]      i_axi_bresp;    // Write response
    input   wire            i_axi_bvalid;  // Write reponse valid
    output  wire            o_axi_bready;  // Response ready
// AXI read address channel signals
    input   wire            i_axi_arready;  // Read address ready
    output  wire    [C_AXI_ID_WIDTH-1:0]    o_axi_arid; // Read ID
    output  reg [C_AXI_ADDR_WIDTH-1:0]  o_axi_araddr;   // Read address
    output  wire    [$clog2(MAX_BURST_LENGTH)-1:0]      o_axi_arlen;    // Read Burst Length
    output  wire    [BURST_SIZE_ENCODING_WIDTH-1:0]     o_axi_arsize;   // Read Burst size
    output  wire    [1:0]       o_axi_arburst;  // Read Burst type
    output  wire    [0:0]       o_axi_arlock;   // Read lock type
    output  wire    [CACHE_BITWIDTH-1:0]        o_axi_arcache;  // Read Cache type
    output  wire    [PROT_BITWIDTH-1:0]     o_axi_arprot;   // Read Protection type
    output  wire    [QOS_BITWIDTH-1:0]      o_axi_arqos;    // Read Quality of Svc
    output  reg         o_axi_arvalid;  // Read address valid
// AXI read data channel signals
    input wire [C_AXI_ID_WIDTH-1:0] i_axi_rid;     // Response ID
    input   wire    [1:0]       i_axi_rresp;   // Read response
    input   wire            i_axi_rvalid;  // Read reponse valid
    input wire [C_AXI_DATA_WIDTH-1:0] i_axi_rdata;    // Read data
    input   wire            i_axi_rlast;    // Read last
    output  wire            o_axi_rready;  // Read Response ready
always @(posedge clk)
begin
    if(reset) o_axi_wstrb <= 0;
    // burst alignment mechanism, see [url]https://i.imgur.com/jKbzfFo.png[/url]
    // o_axi_wstrb <= (~0) << (o_axi_awaddr % o_axi_awlen);
    // all the bracket variables are for removing verilator width warnings
    else o_axi_wstrb <= ((~0) << (o_axi_awaddr %
                                  {{(C_AXI_ADDR_WIDTH-$clog2(MAX_BURST_LENGTH)){1'b0}}, o_axi_awlen}));
end
wire write_response_is_ok = i_axi_bvalid && ((i_axi_bresp == 'b00) || (i_axi_bresp == 'b01));
// need to implement data re-transmission
wire write_response_is_not_ok = i_axi_bvalid && !((i_axi_bresp == 'b00) || (i_axi_bresp == 'b01));
begin
    if(reset)
    begin
        o_axi_wvalid <= 0;
    end
    else if(!(o_axi_wvalid && !i_axi_wready))
    begin
        // Note that both o_axi_awsize , o_axi_awlen are of hardware constants, so no multiply hardware
        // since this is for testing, WDATA just uses some values up to the total size of the write address space
        // Note: a master must not wait for AWREADY to be asserted before driving WVALID
        o_axi_wvalid <= (o_axi_wlast) ? 0 :
                        (o_axi_wdata < (o_axi_awsize*o_axi_awlen));
    end
end
wire ddr_write_address_range_is_valid = (o_axi_awaddr < (1 << C_AXI_ADDR_WIDTH));
begin
    if(reset) o_axi_awvalid <= 0;
    // AXI specification: A3.3.1 Dependencies between channel handshake signal
    // the VALID signal of the AXI interface sending information must not be dependent on
    // the READY signal of the AXI interface receiving that information
    // this is to prevent deadlock
    // since AXI slave could wait for i_axi_awvalid to be true before setting o_axi_awready true.
    // Note: For same interface, VALID cannot depend upon READY, but READY can depends upon VALID
    // Note: Once VALID is asserted, it MUST be kept asserted until READY is asserted.
    //       VALID signal needs to be set (initially) independent of READY signal,
    //       and then only ever adjusted if !(VALID && !READY)
    // Note: the master must not wait for the slave to assert AWREADY before asserting AWVALID
    // Note: (!(o_axi_awvalid && !i_axi_awready)) == (!awvalid || awready)
    //       == (!awvalid || (awvalid && awready)).
    //       it means "no transaction in progress or transaction accepted"
    else if(!(o_axi_awvalid && !i_axi_awready))
            o_axi_awvalid <= /*i_axi_awready &&*/ (ddr_write_address_range_is_valid);
end
wire write_transaction_is_accepted = (o_axi_wvalid) && (i_axi_wready);
wire address_write_transaction_is_accepted = (o_axi_awvalid) && (i_axi_awready);
begin
    if(reset)
    begin
        o_axi_awaddr <= 0;
        //o_axi_wdata <= 0;
    end
    else if(address_write_transaction_is_accepted)
    begin
        o_axi_awaddr <= o_axi_awaddr + 1;
        //o_axi_wdata <= o_axi_wdata + 1;
    end
end
begin
    if(reset)
    begin
        //o_axi_awaddr <= 0;
        o_axi_wdata <= 0;
    end
    else if(write_transaction_is_accepted)
    begin
        //o_axi_awaddr <= o_axi_awaddr + 1;
    end
end
`ifdef LOOPBACK
wire read_address_contains_loopback_data =
(o_axi_awaddr > (o_axi_araddr + {{(C_AXI_ADDR_WIDTH-$clog2(MAX_BURST_LENGTH)){1'b0}}, o_axi_awlen}));
`endif
wire ddr_read_address_range_is_valid = (o_axi_araddr < (1 << C_AXI_ADDR_WIDTH));
begin
    if(reset) o_axi_arvalid <= 0;
    // since AXI slave could wait for i_axi_arvalid to be true before setting o_axi_arready true.
    // Note: the master must not wait for the slave to assert ARREADY before asserting ARVALID
    // Note: (!(o_axi_arvalid && !i_axi_arready)) == (!arvalid || arready)
    //       == (!arvalid || (arvalid && arready)).
    // Note: o_axi_rready is used for backpressure mechanism
    else if(!(o_axi_arvalid && !i_axi_arready))
        `ifdef LOOPBACK
            o_axi_arvalid <= /*i_axi_arready &&*/ (ddr_read_address_range_is_valid) &&
                            (read_address_contains_loopback_data) &&
                            (o_axi_bready && i_axi_bvalid && write_response_is_ok);
        `else
            o_axi_arvalid <= /*i_axi_arready &&*/ (ddr_read_address_range_is_valid);
        `endif
end
reg [$clog2(MAX_BURST_LENGTH)-1:0] num_of_write_transactions;
begin
    if(reset) num_of_write_transactions <= 0;
    else if(o_axi_wvalid && i_axi_wready)
            num_of_write_transactions <= (o_axi_wlast) ? 0 : num_of_write_transactions + 1;
end
begin
    if(reset) o_axi_wlast <= 0;
    else o_axi_wlast <= (num_of_write_transactions == (o_axi_awlen - 1));
end
//assign o_axi_wlast = 0;
assign o_axi_awid = 0;
assign o_axi_awlen = 15; // each burst has (Burst_Length = AxLEN[7:0] + 1) data transfers
/* verilator lint_off WIDTH */
assign o_axi_awsize = $clog2(C_AXI_DATA_WIDTH/NUM_OF_BITS_PER_BYTES); // 128 bits (16 bytes) of data when AxSIZE[2:0] = 3'b100
// Burst_Length = AxLEN[7:0] + 1, to accommodate the extended burst length of the INCR burst type in AXI4.
/* verilator lint_on WIDTH */
assign o_axi_awburst = INCR_BURST_TYPE;
assign o_axi_awlock = 0;
assign o_axi_awcache = 0;
assign o_axi_awprot = 0;
assign o_axi_awqos = 0; // no priority or QoS concept
assign o_axi_arqos = 0; // no priority or QoS concept
assign o_axi_arburst = INCR_BURST_TYPE;
assign o_axi_arsize = $clog2(C_AXI_DATA_WIDTH/NUM_OF_BITS_PER_BYTES); // 128 bits (16 bytes) of data when AxSIZE[2:0] = 3'b100
assign o_axi_arlen = 15; // each burst has (Burst_Length = AxLEN[7:0] + 1) data transfers
assign o_axi_arprot = 3'b010; // {data access, non-secure access, unprivileged access}
assign o_axi_arlock = 0; // AXI4 does not support locked transactions.
assign o_axi_arcache = 0; // mostly used for HPS (hard processor system) such as ARM hard CPU IP
assign o_axi_arid = 0; // there is one AXI slave which is the DDR memory (A, B, or C) ?
// what situations will render data requester (AXI master) busy to receive read response ??
// such as AXI interconnect where arbitration will fail to acquire the data transfer priority
// such as the internal cache storage to store the data from external DDR memory is now full
// So, let's use a random value that is $anyseq in formal verification
assign o_axi_rready = (reset) ? 1 : `ifdef FORMAL $anyseq `else (!cache_is_full) `endif;
// The master can assert BREADY before BVALID is asserted.
assign o_axi_bready = (reset) ? 1 : `ifdef FORMAL $anyseq `else (i_axi_bvalid) `endif;
wire address_read_transaction_is_accepted = (o_axi_arvalid) && (i_axi_arready);
begin
    if(reset) o_axi_araddr <= 0;
    // When ARVALID & ARREADY are both high the next ARADDR can be generated
    // because the current address for the current transfer is now complete (ARVALID & ARREADY).
    else if(address_read_transaction_is_accepted)
        o_axi_araddr <= o_axi_araddr + 1; // increments DDR address to read instructions from
end
wire arm_write_param_enable;
wire [C_AXI_DATA_WIDTH-1:0] arm_write_param_data;
wire cache_is_empty;
wire [$clog2(C_SIZE_OF_CACHE)-1:0] cache_address_for_reading;
assign cache_address_for_reading = 0; // for testing only
wire valid_read_response_does_not_contain_error_messages = i_axi_rvalid && (i_axi_rresp == 0);
wire cache_is_full; // needed since C_SIZE_OF_CACHE is always smaller than SIZE_OF_DDR_MEMORY
// for storing neural network parameters (weights and biases) at destination side,
// so this bram acts as intermediate cache (much smaller size than DDR memory) for the neural network
// no need AXI protocol in order to save logic usage, thus lesser area and power consumption
cache_controller #(.C_DATA_WIDTH(C_AXI_DATA_WIDTH), .C_SIZE_OF_CACHE(C_SIZE_OF_CACHE)) nn_feature_cache
    .clk(clk), .reset(reset),
    .i_data(i_axi_rdata), // NN params coming from DDR memory
    .i_data_is_valid
     ((o_axi_rready && valid_read_response_does_not_contain_error_messages)), // DDR data is valid
    .i_addr(cache_address_for_reading),
    .full(cache_is_full), // NN params cache is full
    .o_data(arm_write_param_data), // NN params going to neural network layers
    .o_data_is_valid(arm_write_param_enable), // neural network layers to start another intermediate computations
    .empty(cache_is_empty) // no NN params to feed into the neural network layers
`ifdef FORMAL
localparam SIXTH_ADDRESS_IN_REQUEST = 6;
initial assume(reset);
reg first_clock_had_passed = 0;
always @(posedge clk) first_clock_had_passed <= 1;
    if(first_clock_had_passed)
        cover((o_axi_araddr > SIXTH_ADDRESS_IN_REQUEST) && address_read_transaction_is_accepted &&
                $past(i_axi_arready) && $past(o_axi_rready) && !o_axi_rready);
`endif
endmodule
You will struggle to find anyone to do your work for you. That is a lot of code to test. Why not specify what the problem is with a clear SMALL usecase example. Or ask more specific questions?
You dont provide any specific problems, or help us. 120 posts in now.
Why cant you just debug the slave?
That is why I never provide code to ask about the wrong AXI waveform until someone asks for the code. And data loopback test is already a SMALL testcase.
From my personal AXi experience with locating which signals to debug, there is actually not really much a need to check the code if waveform could tells it all, in my case, RDATA returns XXX unknown bits for data loopback case.
I had already asked very specific question about the simulation waveform. See posts #115 and #116
As for the slave, I do not have the source code of Xilinx BRAM IP. And I am only provided with its slave AXI interface signals.
Is it true that XILINX AXI slave IP does not support simultaneous two-way data transfer ?
In other words, for different AWADDR and ARADDR, AW* channel cannot be active when AR* channel is active ?
Should not be. Better you ask this in the Xilinx forums.
As for your AXI enlightenment and wisdom, I would recommend reading all the AXI related articles in this blog.
https://zipcpu.com/formal/2019/09/06/axi-story.html
I know what is wrong. Internal BRAM_en signal is not asserted but what actually caused this ?
Something is very wrong. clk and reset signals have been connected correctly in the module instantiation.
8
9
10
11
12
13
14
15
16
17
bram_axi_controller #(.C_AXI_DATA_WIDTH(C_AXI_DATA_WIDTH)) ddr_nn_params
    .o_axi_awready(axi_awready[0]), .i_axi_awid(axi_awid[0]),       .i_axi_awaddr(axi_awaddr[0]),
    .i_axi_awlen(axi_awlen[0]),     .i_axi_awsize(axi_awsize[0]),   .i_axi_awburst(axi_awburst[0]),
    .i_axi_awlock(axi_awlock[0]),   .i_axi_awcache(axi_awcache[0]), .i_axi_awprot(axi_awprot[0]),
    .i_axi_awqos(axi_awqos[0]),     .i_axi_awvalid(axi_awvalid[0]), .o_axi_wready(axi_wready[0]),
    .i_axi_wdata(axi_wdata[0]),     .i_axi_wstrb(axi_wstrb[0]),     .i_axi_wlast(axi_wlast[0]),
    .i_axi_wvalid(axi_wvalid[0]),   .o_axi_bid(axi_bid[0]),         .o_axi_bresp(axi_bresp[0]),
    .o_axi_bvalid(axi_bvalid[0]),   .i_axi_bready(axi_bready[0]),   .o_axi_arready(axi_arready[0]),
    .i_axi_arid(axi_arid[0]),       .i_axi_araddr(axi_araddr[0]),   .i_axi_arlen(axi_arlen[0]),
    .i_axi_arsize(axi_arsize[0]),   .i_axi_arburst(axi_arburst[0]), .i_axi_arlock(axi_arlock[0]),
    .i_axi_arcache(axi_arcache[0]), .i_axi_arprot(axi_arprot[0]),   .i_axi_arqos(axi_arqos[0]),
    .i_axi_arvalid(axi_arvalid[0]), .o_axi_rid(axi_rid[0]),         .o_axi_rresp(axi_rresp[0]),
    .o_axi_rvalid(axi_rvalid[0]),   .o_axi_rdata(axi_rdata[0]),     .o_axi_rlast(axi_rlast[0]),
    .i_axi_rready(axi_rready[0])
The posted code doesn't show any of the bram interface ports or the bram itself.
See this internal VHDL source code generated by Vivado AXI BRAM controller IP
addra_bram_addra_i is not driven at all
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
450
451
452
453
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
501
502
503
504
505
506
507
508
509
510
511
512
513
514
515
516
517
518
519
520
521
522
523
524
525
526
527
528
529
530
531
532
533
534
535
536
537
538
539
540
541
542
543
544
545
546
547
548
549
550
551
552
553
554
555
556
557
558
559
560
561
562
563
564
565
566
567
568
569
570
571
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
595
596
597
598
599
600
601
602
603
604
605
606
607
608
609
610
611
612
613
614
615
616
617
618
619
620
621
622
623
624
625
626
627
628
629
630
631
632
633
634
635
636
637
638
639
640
641
642
643
644
645
646
647
648
649
650
651
652
653
654
655
656
657
658
659
660
661
662
663
664
665
666
667
668
669
670
671
672
673
674
675
676
677
678
679
680
681
682
683
684
685
686
687
688
689
690
691
692
693
694
695
696
697
698
699
700
701
702
703
704
705
706
707
708
709
710
711
712
713
714
715
716
717
718
719
720
721
722
723
724
725
726
727
728
729
730
731
732
733
734
735
736
737
738
739
740
741
742
743
744
745
746
747
748
749
750
751
752
753
754
755
756
757
758
759
760
761
762
763
764
765
766
767
768
769
770
771
772
773
774
775
776
777
778
779
780
781
782
783
784
785
786
787
788
789
790
791
792
793
794
795
796
797
798
799
800
801
802
803
804
805
806
807
808
809
810
811
812
813
814
815
816
817
818
819
820
821
822
823
824
825
826
827
828
829
830
831
832
833
834
835
836
837
838
839
840
841
842
843
844
845
846
847
848
849
850
851
852
853
854
855
856
857
858
859
860
861
862
863
864
865
866
867
868
869
870
871
872
873
874
875
876
877
878
879
880
881
882
883
884
885
886
887
888
889
890
891
892
893
894
895
896
897
898
899
900
901
902
903
904
905
906
907
908
909
910
911
912
913
914
915
916
917
918
919
920
921
922
923
924
925
926
927
928
929
930
931
932
933
934
935
936
937
938
939
940
941
942
943
944
945
946
947
948
949
950
951
952
953
954
955
956
957
958
959
960
961
962
963
964
965
966
967
968
969
970
971
972
973
974
975
976
977
978
979
980
981
982
983
984
985
986
987
988
989
990
991
992
993
994
995
996
997
998
999
1000
1001
1002
1003
1004
1005
1006
1007
1008
1009
1010
1011
1012
1013
1014
1015
1016
1017
1018
1019
1020
1021
1022
1023
1024
1025
1026
1027
1028
1029
1030
1031
1032
1033
1034
1035
1036
1037
1038
1039
1040
1041
1042
1043
1044
1045
1046
1047
1048
1049
1050
1051
1052
1053
1054
1055
1056
1057
1058
1059
1060
1061
1062
1063
1064
1065
1066
1067
1068
1069
1070
1071
1072
1073
1074
1075
1076
1077
1078
1079
1080
1081
1082
1083
1084
1085
1086
1087
1088
1089
1090
1091
1092
1093
1094
1095
1096
1097
1098
1099
1100
1101
1102
1103
1104
1105
1106
1107
1108
1109
1110
1111
1112
1113
1114
1115
1116
1117
1118
1119
1120
1121
1122
1123
1124
1125
1126
1127
1128
1129
1130
1131
1132
1133
1134
1135
1136
1137
1138
1139
1140
1141
1142
1143
1144
1145
1146
1147
1148
1149
1150
1151
1152
1153
1154
1155
1156
1157
1158
1159
1160
1161
1162
1163
1164
1165
1166
1167
1168
1169
1170
1171
1172
1173
1174
1175
1176
1177
1178
1179
1180
1181
1182
1183
1184
1185
1186
1187
1188
1189
1190
1191
1192
1193
1194
1195
1196
1197
1198
1199
1200
1201
1202
1203
1204
1205
1206
1207
1208
1209
1210
1211
1212
1213
1214
1215
1216
1217
1218
1219
1220
1221
1222
1223
1224
1225
1226
1227
1228
1229
1230
1231
1232
1233
1234
1235
1236
1237
1238
1239
1240
1241
1242
1243
1244
1245
1246
1247
1248
1249
1250
1251
1252
1253
1254
1255
1256
1257
1258
1259
1260
1261
1262
1263
1264
1265
1266
1267
1268
1269
1270
1271
1272
1273
1274
1275
1276
1277
1278
1279
1280
1281
1282
1283
1284
1285
1286
1287
1288
1289
1290
1291
1292
1293
1294
1295
1296
1297
1298
1299
1300
1301
1302
1303
1304
1305
1306
1307
1308
1309
1310
1311
1312
1313
1314
1315
1316
1317
1318
1319
1320
1321
1322
1323
1324
1325
1326
1327
1328
1329
1330
1331
1332
1333
1334
1335
1336
1337
1338
1339
1340
1341
1342
1343
1344
1345
1346
1347
1348
1349
1350
1351
1352
1353
1354
1355
1356
1357
1358
1359
1360
1361
1362
1363
1364
1365
1366
1367
1368
1369
1370
1371
1372
1373
1374
1375
1376
1377
1378
1379
1380
1381
1382
1383
1384
1385
1386
1387
1388
1389
1390
1391
1392
1393
1394
1395
1396
1397
1398
1399
1400
1401
1402
1403
1404
1405
1406
1407
1408
1409
1410
1411
1412
1413
1414
1415
1416
1417
1418
1419
1420
1421
1422
1423
1424
1425
1426
1427
1428
1429
1430
1431
1432
1433
1434
1435
1436
1437
1438
1439
1440
1441
1442
1443
1444
1445
1446
1447
1448
1449
1450
1451
1452
1453
1454
1455
1456
1457
1458
1459
1460
1461
1462
1463
1464
1465
1466
1467
1468
1469
1470
1471
1472
1473
1474
1475
1476
1477
1478
1479
1480
1481
1482
1483
1484
1485
1486
1487
1488
1489
1490
1491
1492
1493
1494
1495
1496
1497
1498
1499
1500
1501
1502
1503
1504
1505
1506
1507
1508
1509
1510
1511
1512
1513
1514
1515
1516
1517
1518
1519
1520
1521
1522
1523
1524
1525
1526
1527
1528
1529
1530
1531
1532
1533
1534
1535
1536
1537
1538
1539
1540
1541
1542
1543
1544
1545
1546
1547
1548
1549
1550
1551
1552
1553
1554
1555
1556
1557
1558
1559
1560
1561
1562
1563
1564
1565
1566
1567
1568
1569
1570
1571
1572
1573
1574
1575
1576
1577
1578
1579
1580
1581
1582
1583
1584
1585
1586
1587
1588
1589
1590
1591
1592
1593
1594
1595
1596
1597
1598
1599
1600
1601
1602
1603
1604
1605
1606
1607
1608
1609
1610
1611
1612
1613
1614
1615
1616
1617
1618
1619
1620
1621
1622
1623
1624
1625
1626
1627
1628
1629
1630
1631
-- SRL_FIFO entity and architecture
-- ** DISCLAIMER OF LIABILITY                                             **
-- ** This text/file contains proprietary, confidential                   **
-- ** information of Xilinx, Inc., is distributed under                   **
-- ** license from Xilinx, Inc., and may be used, copied                  **
-- ** and/or disclosed only pursuant to the terms of a valid              **
-- ** license agreement with Xilinx, Inc. Xilinx hereby                   **
-- ** grants you a license to use this text/file solely for               **
-- ** design, simulation, implementation and creation of                  **
-- ** design files limited to Xilinx devices or technologies.             **
-- ** Use with non-Xilinx devices or technologies is expressly            **
-- ** prohibited and immediately terminates your license unless           **
-- ** covered by a separate agreement.                                    **
-- ** Xilinx is providing this design, code, or information               **
-- ** "as-is" solely for use in developing programs and                   **
-- ** solutions for Xilinx devices, with no obligation on the             **
-- ** part of Xilinx to provide support. By providing this design,        **
-- ** code, or information as one possible implementation of              **
-- ** this feature, application or standard, Xilinx is making no          **
-- ** representation that this implementation is free from any            **
-- ** claims of infringement. You are responsible for obtaining           **
-- ** any rights you may require for your implementation.                 **
-- ** Xilinx expressly disclaims any warranty whatsoever with             **
-- ** respect to the adequacy of the implementation, including            **
-- ** but not limited to any warranties or representations that this      **
-- ** implementation is free from claims of infringement, implied         **
-- ** warranties of merchantability or fitness for a particular           **
-- ** purpose.                                                            **
-- ** Xilinx products are not intended for use in life support            **
-- ** appliances, devices, or systems. Use in such applications is        **
-- ** expressly prohibited.                                               **
-- ** Any modifications that are made to the Source Code are              **
-- ** done at the user’s sole risk and will be unsupported.               **
-- ** The Xilinx Support Hotline does not have access to source           **
-- ** code and therefore cannot answer specific questions related         **
-- ** to source HDL. The Xilinx Hotline support of original source        **
-- ** code IP shall only address issues and questions related             **
-- ** to the standard Netlist version of the core (and thus               **
-- ** indirectly, the original core source).                              **
-- ** Copyright (c) 2001-2013 Xilinx, Inc. All rights reserved.           **
-- ** This copyright and support notice must be retained as part          **
-- ** of this text at all times.                                          **
-- Filename:        srl_fifo.vhd
-- Description:
-- VHDL-Standard:   VHDL'93
-- Structure:
--              srl_fifo.vhd
-- Author:          goran
-- Revision:        $Revision: 1.1.4.1 $
-- Date:            $Date: 2010/09/14 22:35:47 $
-- History:
--   goran  2001-05-11    First Version
--   KC     2001-06-20    Added Addr as an output port, for use as an occupancy
--                        value
--   DCW    2002-03-12    Structural implementation of synchronous reset for
--                        Data_Exists DFF (using FDR)
--   jam    2002-04-12    added C_XON generic for mixed vhdl/verilog sims
--   als    2002-04-18    added default for XON generic in SRL16E, FDRE, and FDR
--                        component declarations
--     DET     1/17/2008     v4_00_a
--     - Incorporated new disclaimer header
-- Naming Conventions:
--      active low signals:                     "*_n"
--      clock signals:                          "clk", "clk_div#", "clk_#x"
--      reset signals:                          "rst", "rst_n"
--      generics:                               "C_*"
--      user defined types:                     "*_TYPE"
--      state machine next state:               "*_ns"
--      state machine current state:            "*_cs"
--      combinatorial signals:                  "*_com"
--      pipelined or register delay signals:    "*_d#"
--      counter signals:                        "*cnt*"
--      clock enable signals:                   "*_ce"
--      internal version of output port         "*_i"
--      device pins:                            "*_pin"
--      ports:                                  - Names begin with Uppercase
--      processes:                              "*_PROCESS"
--      component instantiations:               "<ENTITY_>I_<#|FUNC>
library IEEE;
use IEEE.std_logic_1164.all;
library unisim;
use unisim.all;
entity SRL_FIFO is
  generic (
    C_DATA_BITS : natural := 8;
    C_DEPTH     : natural := 16;
    C_XON       : boolean := false
  port (
    Clk         : in  std_logic;
    Reset       : in  std_logic;
    FIFO_Write  : in  std_logic;
    Data_In     : in  std_logic_vector(0 to C_DATA_BITS-1);
    FIFO_Read   : in  std_logic;
    Data_Out    : out std_logic_vector(0 to C_DATA_BITS-1);
    FIFO_Full   : out std_logic;
    Data_Exists : out std_logic;
    Addr        : out std_logic_vector(0 to 3) -- Added Addr as a port
end entity SRL_FIFO;
architecture IMP of SRL_FIFO is
attribute DowngradeIPIdentifiedWarnings: string;
attribute DowngradeIPIdentifiedWarnings of IMP : architecture is "yes";
  component SRL16E is
      -- pragma translate_off
    generic (
      INIT : bit_vector := X"0000"
      -- pragma translate_on
    port (
      CE  : in  std_logic;
      D   : in  std_logic;
      Clk : in  std_logic;
      A0  : in  std_logic;
      A1  : in  std_logic;
      A2  : in  std_logic;
      A3  : in  std_logic;
      Q   : out std_logic);
  end component SRL16E;
  component LUT4
    generic(
    port (
      O  : out std_logic;
      I0 : in  std_logic;
      I1 : in  std_logic;
      I2 : in  std_logic;
      I3 : in  std_logic);
  end component;
  component MULT_AND
    port (
      I0 : in  std_logic;
      I1 : in  std_logic;
      LO : out std_logic);
  end component;
  component MUXCY_L
    port (
      DI : in  std_logic;
      CI : in  std_logic;
      S  : in  std_logic;
  end component;
  component XORCY
    port (
      LI : in  std_logic;
      CI : in  std_logic;
      O  : out std_logic);
  end component;
  component FDRE is
    port (
      Q  : out std_logic;
      C  : in  std_logic;
      CE : in  std_logic;
      D  : in  std_logic;
      R  : in  std_logic);
  end component FDRE;
  component FDR is
    port (
      Q  : out std_logic;
      C  : in  std_logic;
      D  : in  std_logic;
      R  : in  std_logic);
  end component FDR;
  signal addr_i       : std_logic_vector(0 to 3);
  signal buffer_Full  : std_logic;
  signal buffer_Empty : std_logic;
  signal next_Data_Exists : std_logic;
  signal data_Exists_I    : std_logic;
  signal valid_Write : std_logic;
  signal hsum_A  : std_logic_vector(0 to 3);
  signal sum_A   : std_logic_vector(0 to 3);
  signal addr_cy : std_logic_vector(0 to 4);
begin  -- architecture IMP
  buffer_Full <= '1' when (addr_i = "1111") else '0';
  FIFO_Full   <= buffer_Full;
  buffer_Empty <= '1' when (addr_i = "0000") else '0';
  next_Data_Exists <= (data_Exists_I and not buffer_Empty) or
                      (buffer_Empty and FIFO_Write) or
                      (data_Exists_I and not FIFO_Read);
  Data_Exists_DFF : FDR
    port map (
      Q  => data_Exists_I,            -- [out std_logic]
      C  => Clk,                      -- [in  std_logic]
      D  => next_Data_Exists,         -- [in  std_logic]
      R  => Reset);                   -- [in std_logic]
  Data_Exists <= data_Exists_I;
  valid_Write <= FIFO_Write and (FIFO_Read or not buffer_Full);
  addr_cy(0) <= valid_Write;
  Addr_Counters : for I in 0 to 3 generate
    hsum_A(I) <= (FIFO_Read xor addr_i(I)) and (FIFO_Write or not buffer_Empty);
    MUXCY_L_I : MUXCY_L
      port map (
        DI => addr_i(I),                  -- [in  std_logic]
        CI => addr_cy(I),               -- [in  std_logic]
        S  => hsum_A(I),                -- [in  std_logic]
        LO => addr_cy(I+1));            -- [out std_logic]
    XORCY_I : XORCY
      port map (
        LI => hsum_A(I),                -- [in  std_logic]
        O  => sum_A(I));                -- [out std_logic]
    FDRE_I : FDRE
      port map (
        Q  => addr_i(I),                  -- [out std_logic]
        CE => data_Exists_I,            -- [in  std_logic]
        D  => sum_A(I),                 -- [in  std_logic]
  end generate Addr_Counters;
  FIFO_RAM : for I in 0 to C_DATA_BITS-1 generate
    SRL16E_I : SRL16E
      generic map (
        INIT => x"0000")
      port map (
        CE  => valid_Write,             -- [in  std_logic]
        D   => Data_In(I),              -- [in  std_logic]
        Clk => Clk,                     -- [in  std_logic]
        A0  => addr_i(0),                 -- [in  std_logic]
        A1  => addr_i(1),                 -- [in  std_logic]
        A2  => addr_i(2),                 -- [in  std_logic]
        A3  => addr_i(3),                 -- [in  std_logic]
        Q   => Data_Out(I));            -- [out std_logic]
  end generate FIFO_RAM;
-- INT_ADDR_PROCESS
-- This process assigns the internal address to the output port
  INT_ADDR_PROCESS:process (addr_i)
  begin   -- process
    Addr <= addr_i;
  end process;
end architecture IMP;
-- axi_bram_ctrl_funcs.vhd
-- (c) Copyright [2010 - 2013] Xilinx, Inc. All rights reserved.
-- This file contains confidential and proprietary information
-- of Xilinx, Inc. and is protected under U.S. and
-- international copyright and other intellectual property
-- laws.
-- DISCLAIMER
-- This disclaimer is not a license and does not grant any
-- rights to the materials distributed herewith. Except as
-- otherwise provided in a valid license issued to you by
-- Xilinx, and to the maximum extent permitted by applicable
-- law: (1) THESE MATERIALS ARE MADE AVAILABLE "AS IS" AND
-- WITH ALL FAULTS, AND XILINX HEREBY DISCLAIMS ALL WARRANTIES
-- AND CONDITIONS, EXPRESS, IMPLIED, OR STATUTORY, INCLUDING
-- BUT NOT LIMITED TO WARRANTIES OF MERCHANTABILITY, NON-
-- INFRINGEMENT, OR FITNESS FOR ANY PARTICULAR PURPOSE; and
-- (2) Xilinx shall not be liable (whether in contract or tort,
-- including negligence, or under any other theory of
-- liability) for any loss or damage of any kind or nature
-- related to, arising under or in connection with these
-- materials, including for any direct, or any indirect,
-- special, incidental, or consequential loss or damage
-- (including loss of data, profits, goodwill, or any type of
-- loss or damage suffered as a result of any action brought
-- by a third party) even if such damage or loss was
-- reasonably foreseeable or Xilinx had been advised of the
-- possibility of the same.
-- CRITICAL APPLICATIONS
-- Xilinx products are not designed or intended to be fail-
-- safe, or for use in any application requiring fail-safe
-- performance, such as life-support or safety devices or
-- systems, Class III medical devices, nuclear facilities,
-- applications related to the deployment of airbags, or any
-- other applications that could lead to death, personal
-- injury, or severe property or environmental damage
-- (individually and collectively, "Critical
-- Applications"). Customer assumes the sole risk and
-- liability of any use of Xilinx products in Critical
-- Applications, subject only to applicable laws and
-- regulations governing limitations on product liability.
-- THIS COPYRIGHT NOTICE AND DISCLAIMER MUST BE RETAINED AS
-- PART OF THIS FILE AT ALL TIMES.
-- Filename:        axi_bram_ctrl_funcs.vhd
-- Description:     Support functions for axi_bram_ctrl library modules.
-- History:
-- JLJ      2/1/2011         v1.03a
--  Migrate to v1.03a.
--  Plus minor code cleanup.
-- JLJ      2/16/2011      v1.03a
--  Update ECC size on 128-bit data width configuration.
-- JLJ      2/23/2011      v1.03a
--  Add MIG functions for Hsiao ECC.
-- JLJ      2/24/2011      v1.03a
--  Add Find_ECC_Size function.
-- JLJ      3/15/2011      v1.03a
--  Add REDUCTION_OR function.
-- JLJ      3/17/2011      v1.03a
--  Recode Create_Size_Max with a case statement.
-- JLJ      3/31/2011      v1.03a
--  Add coverage tags.
-- JLJ      5/6/2011      v1.03a
--  Remove usage of C_FAMILY.
--  Remove Family_To_LUT_Size function.
--  Remove String_To_Family function.
--      generics:                               "C_*"
library IEEE;
package axi_bram_ctrl_funcs is
  type TARGET_FAMILY_TYPE is (
                              -- pragma xilinx_rtl_off
                              SPARTAN3,
                              VIRTEX4,
                              VIRTEX5,
                              SPARTAN3E,
                              SPARTAN3A,
                              SPARTAN3AN,
                              SPARTAN3Adsp,
                              SPARTAN6,
                              VIRTEX6,
                              VIRTEX7,
                              KINTEX7,
                              -- pragma xilinx_rtl_on
                              RTL
  -- function String_To_Family (S : string; Select_RTL : boolean) return TARGET_FAMILY_TYPE;
  -- Get the maximum number of inputs to a LUT.
  -- function Family_To_LUT_Size(Family : TARGET_FAMILY_TYPE) return integer;
  function Equal_String( str1, str2 : STRING ) RETURN BOOLEAN;
  function log2(x : natural) return integer;
  function Int_ECC_Size (i: integer) return integer;
  function Find_ECC_Size (i: integer; j: integer) return integer;
  function Find_ECC_Full_Bit_Size (i: integer; j: integer) return integer;
  function Create_Size_Max (i: integer) return std_logic_vector;
  function REDUCTION_OR (A: in std_logic_vector) return std_logic;
  function REDUCTION_XOR (A: in std_logic_vector) return std_logic;
  function REDUCTION_NOR (A: in std_logic_vector) return std_logic;
  function BOOLEAN_TO_STD_LOGIC (A: in BOOLEAN) return std_logic;
end package axi_bram_ctrl_funcs;
library IEEE;
use IEEE.numeric_std.all;
package body axi_bram_ctrl_funcs is
-- Function:    Int_ECC_Size
-- Purpose:     Determine internal size of ECC when enabled.
function Int_ECC_Size (i: integer) return integer is
begin
--coverage off
    if (i = 32) then
        return 7;   -- 7-bits ECC for 32-bit data
                    -- ECC port size fixed @ 8-bits
    elsif (i = 64) then
        return 8;
    elsif (i = 128) then
        return 9;   -- Hsiao is 9-bits for 128-bit data.
    else
        return 0;
    end if;
--coverage on
end Int_ECC_Size;
-- Function:    Find_ECC_Size
-- Purpose:     Determine external size of ECC signals when enabled.
function Find_ECC_Size (i: integer; j: integer) return integer is
begin
--coverage off
    if (i = 1) then
        if (j = 32) then
            return 8;   -- Keep at 8 for port size matchings
                        -- Only 7-bits ECC per 32-bit data
        elsif (j = 64) then
            return 8;
        elsif (j = 128) then
            return 9;
        else
            return 0;
        end if;
    else
        return 0;
        -- ECC data width = 0 when C_ECC = 0 (disabled)
    end if;
--coverage on
end Find_ECC_Size;
-- Function:    Find_ECC_Full_Bit_Size
-- Purpose:     Determine external size of ECC signals when enabled in bytes.
function Find_ECC_Full_Bit_Size (i: integer; j: integer) return integer is
begin
--coverage off
    if (i = 1) then
        if (j = 32) then
            return 8;
        elsif (j = 64) then
            return 8;
            return 16;
        else
            return 0;
        end if;
    else
        return 0;
    end if;
--coverage on
end Find_ECC_Full_Bit_Size;
-- Function:    Create_Size_Max
-- Purpose:     Create maximum value for AxSIZE based on AXI data bus width.
    return std_logic_vector is
variable size_vector : std_logic_vector (2 downto 0);
begin
    case (i) is
        when 32 =>      size_vector := "010";           -- 2h (4 bytes)
        when 64 =>      size_vector := "011";           -- 3h (8 bytes)
        when 128 =>     size_vector := "100";           -- 4h (16 bytes)
        when 256 =>     size_vector := "101";           -- 5h (32 bytes)
        when 512 =>     size_vector := "110";           -- 5h (32 bytes)
        when 1024 =>    size_vector := "111";           -- 5h (32 bytes)
--coverage off
        when others =>  size_vector := "000";           -- 0h
--coverage on
    end case;
    return (size_vector);
end function Create_Size_Max;
-- Function:    REDUCTION_OR
-- Purpose:     New in v1.03a
function REDUCTION_OR (A: in std_logic_vector) return std_logic is
variable tmp : std_logic := '0';
begin
    for i in A'range loop
       tmp := tmp or A(i);
    end loop;
    return tmp;
end function REDUCTION_OR;
-- Function:    REDUCTION_XOR
-- Purpose:     Derived from MIG v3.7 ecc_gen module for use by Hsiao ECC.
--              New in v1.03a
function REDUCTION_XOR (A: in std_logic_vector) return std_logic is
begin
       tmp := tmp xor A(i);
  end loop;
  return tmp;
end function REDUCTION_XOR;
-- Function:    REDUCTION_NOR
-- Purpose:     Derived from MIG v3.7 ecc_dec_fix module for use by Hsiao ECC.
--              New in v1.03a
function REDUCTION_NOR (A: in std_logic_vector) return std_logic is
begin
       tmp := tmp or A(i);
  end loop;
  return not tmp;
end function REDUCTION_NOR;
-- Function:    BOOLEAN_TO_STD_LOGIC
--              New in v1.03a
function BOOLEAN_TO_STD_LOGIC (A : in BOOLEAN) return std_logic is
begin
   if A = true then
       return '1';
   else
       return '0';
   end if;
end function BOOLEAN_TO_STD_LOGIC;
function LowerCase_Char(char : character) return character is
begin
--coverage off
    -- If char is not an upper case letter then return char
    if char < 'A' or char > 'Z' then
      return char;
    end if;
    -- Otherwise map char to its corresponding lower case character and
    -- return that
    case char is
      when 'A'    => return 'a'; when 'B' => return 'b'; when 'C' => return 'c'; when 'D' => return 'd';
      when 'E'    => return 'e'; when 'F' => return 'f'; when 'G' => return 'g'; when 'H' => return 'h';
      when 'I'    => return 'i'; when 'J' => return 'j'; when 'K' => return 'k'; when 'L' => return 'l';
      when 'M'    => return 'm'; when 'N' => return 'n'; when 'O' => return 'o'; when 'P' => return 'p';
      when 'Q'    => return 'q'; when 'R' => return 'r'; when 'S' => return 's'; when 'T' => return 't';
      when 'U'    => return 'u'; when 'V' => return 'v'; when 'W' => return 'w'; when 'X' => return 'x';
      when 'Y'    => return 'y'; when 'Z' => return 'z';
      when others => return char;
    end case;
--coverage on
end LowerCase_Char;
-- Returns true if case insensitive string comparison determines that
-- str1 and str2 are equal
function Equal_String ( str1, str2 : STRING ) RETURN BOOLEAN IS
  CONSTANT len1 : INTEGER := str1'length;
  CONSTANT len2 : INTEGER := str2'length;
  VARIABLE equal : BOOLEAN := TRUE;
BEGIN
--coverage off
    IF NOT (len1=len2) THEN
      equal := FALSE;
    ELSE
      FOR i IN str1'range LOOP
        IF NOT (LowerCase_Char(str1(i)) = LowerCase_Char(str2(i))) THEN
          equal := FALSE;
        END IF;
      END LOOP;
    END IF;
--coverage on
    RETURN equal;
END Equal_String;
-- Remove usage of String_To_Family function.
--    function String_To_Family (S : string; Select_RTL : boolean) return TARGET_FAMILY_TYPE is
--    begin  -- function String_To_Family
--    --coverage off
--        if ((Select_RTL) or Equal_String(S, "rtl")) then
--          return RTL;
--        elsif Equal_String(S, "spartan3") or Equal_String(S, "aspartan3") then
--          return SPARTAN3;
--        elsif Equal_String(S, "spartan3E") or Equal_String(S, "aspartan3E") then
--          return SPARTAN3E;
--        elsif Equal_String(S, "spartan3A") or Equal_String(S, "aspartan3A") then
--          return SPARTAN3A;
--        elsif Equal_String(S, "spartan3AN") then
--          return SPARTAN3AN;
--        elsif Equal_String(S, "spartan3Adsp") or Equal_String(S, "aspartan3Adsp") then
--          return SPARTAN3Adsp;
--        elsif Equal_String(S, "spartan6")  or Equal_String(S, "spartan6l") or
--              Equal_String(S, "qspartan6") or Equal_String(S, "aspartan6") or Equal_String(S, "qspartan6l") then
--          return SPARTAN6;
--        elsif Equal_String(S, "virtex4") or Equal_String(S, "qvirtex4")
--           or Equal_String(S, "qrvirtex4") then
--          return VIRTEX4;
--        elsif Equal_String(S, "virtex5") or Equal_String(S, "qrvirtex5") then
--          return VIRTEX5;
--        elsif Equal_String(S, "virtex6") or Equal_String(S, "virtex6l") or Equal_String(S, "qvirtex6") then
--          return VIRTEX6;
--        elsif Equal_String(S, "virtex7") then
--          return VIRTEX7;
--        elsif Equal_String(S, "kintex7") then
--          return KINTEX7;
--    --coverage on
--        else
--          -- assert (false) report "No known target family" severity failure;
--          return RTL;
--        end if;
--    end function String_To_Family;
-- Remove usage of Family_To_LUT_Size function.
--    function Family_To_LUT_Size (Family : TARGET_FAMILY_TYPE) return integer is
--    begin
--    --coverage off
--        if (Family = SPARTAN3) or (Family = SPARTAN3E) or (Family = SPARTAN3A) or
--           (Family = SPARTAN3AN) or (Family = SPARTAN3Adsp) or (Family = VIRTEX4) then
--          return 4;
--        end if;
--        return 6;
--    --coverage on
--    end function Family_To_LUT_Size;
-- Function log2 -- returns number of bits needed to encode x choices
--   x = 0  returns 0
--   x = 1  returns 0
--   x = 2  returns 1
--   x = 4  returns 2, etc.
function log2(x : natural) return integer is
  variable i  : integer := 0;
  variable val: integer := 1;
begin
--coverage off
    if x = 0 then return 0;
    else
      for j in 0 to 29 loop -- for loop for XST
        if val >= x then null;
        else
          i := i+1;
          val := val*2;
        end if;
      end loop;
    -- Fix per CR520627  XST was ignoring this anyway and printing a
    -- Warning in SRP file. This will get rid of the warning and not
    -- impact simulation.
    -- synthesis translate_off
      assert val >= x
        report "Function log2 received argument larger" &
               " than its capability of 2^30. "
        severity failure;
    -- synthesis translate_on
      return i;
    end if;
--coverage on
end function log2;
end package body axi_bram_ctrl_funcs;
-- coregen_comp_defs - entity/architecture pair
-- ** purpose.                                                            **
-- ** Copyright (c) 2008-2013 Xilinx, Inc. All rights reserved.           **
-- Filename:        coregen_comp_defs.vhd
-- Version:         initial
-- Description:
--   Component declarations for all black box netlists generated by
--   running COREGEN and AXI BRAM CTRL when XST elaborated the client core
-- Structure:
--                      -- coregen_comp_defs.vhd
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
PACKAGE coregen_comp_defs IS
-- Start Block Memory Generator Component for blk_mem_gen_v8_3_6
-- Component declaration for blk_mem_gen_v8_3_6 pulled from the  blk_mem_gen_v8_3_6.v
-- Verilog file used to match paramter order for NCSIM compatibility
component blk_mem_gen_v8_3_6
  generic (
  -- Generic Declarations
  --Device Family & Elaboration Directory Parameters:
    C_FAMILY                    : STRING  := "virtex4";
    C_XDEVICEFAMILY             : STRING  := "virtex4";
--    C_ELABORATION_DIR           : STRING  := "";
    C_INTERFACE_TYPE            : INTEGER := 0;
    C_AXI_TYPE                  : INTEGER := 1;
    C_AXI_SLAVE_TYPE            : INTEGER := 0;
    C_HAS_AXI_ID                : INTEGER := 0;
    C_AXI_ID_WIDTH                : INTEGER := 4;
  --General Memory Parameters:
    C_MEM_TYPE                  : INTEGER := 2;
    C_BYTE_SIZE                 : INTEGER := 9;
    C_ALGORITHM                 : INTEGER := 0;
    C_PRIM_TYPE                 : INTEGER := 3;
  --Memory Initialization Parameters:
    C_LOAD_INIT_FILE            : INTEGER := 0;
    C_INIT_FILE_NAME            : STRING  := "";
    C_USE_DEFAULT_DATA          : INTEGER := 0;
    C_DEFAULT_DATA              : STRING  := "111111111";
    C_RST_TYPE                  : STRING  := "SYNC";
  --Port A Parameters:
    --Reset Parameters:
    C_HAS_RSTA                  : INTEGER := 0;
    C_RST_PRIORITY_A            : STRING  := "CE";
    C_RSTRAM_A                  : INTEGER := 0;
    C_INITA_VAL                 : STRING  := "0";
    --Enable Parameters:
    C_HAS_ENA                   : INTEGER := 1;
    C_HAS_REGCEA                : INTEGER := 0;
    --Byte Write Enable Parameters:
    C_USE_BYTE_WEA              : INTEGER := 0;
    C_WEA_WIDTH                 : INTEGER := 1;
    --Write Mode:
    C_WRITE_MODE_A              : STRING  := "WRITE_FIRST";
    --Data-Addr Width Parameters:
    C_WRITE_WIDTH_A             : INTEGER := 4;
    C_READ_WIDTH_A              : INTEGER := 4;
    C_WRITE_DEPTH_A             : INTEGER := 4096;
    C_READ_DEPTH_A              : INTEGER := 4096;
    C_ADDRA_WIDTH               : INTEGER := 12;
  --Port B Parameters:
    --Reset Parameters:
    C_HAS_RSTB                  : INTEGER := 0;
    C_RST_PRIORITY_B            : STRING  := "CE";
    C_RSTRAM_B                  : INTEGER := 0;
    C_INITB_VAL                 : STRING  := "0";
    C_HAS_ENB                   : INTEGER := 1;
    C_HAS_REGCEB                : INTEGER := 0;
    C_USE_BYTE_WEB              : INTEGER := 0;
    C_WEB_WIDTH                 : INTEGER := 1;
    --Write Mode:
    C_WRITE_MODE_B              : STRING  := "WRITE_FIRST";
    C_WRITE_WIDTH_B             : INTEGER := 4;
    C_READ_WIDTH_B              : INTEGER := 4;
    C_WRITE_DEPTH_B             : INTEGER := 4096;
    C_READ_DEPTH_B              : INTEGER := 4096;
    C_ADDRB_WIDTH               : INTEGER := 12;
  --Output Registers/ Pipelining Parameters:
    C_HAS_MEM_OUTPUT_REGS_A     : INTEGER := 0;
    C_HAS_MEM_OUTPUT_REGS_B     : INTEGER := 0;
    C_HAS_MUX_OUTPUT_REGS_A     : INTEGER := 0;
    C_HAS_MUX_OUTPUT_REGS_B     : INTEGER := 0;
    C_MUX_PIPELINE_STAGES       : INTEGER := 0;
   --Input/Output Registers for SoftECC :
    C_HAS_SOFTECC_INPUT_REGS_A  : INTEGER := 0;
    C_HAS_SOFTECC_OUTPUT_REGS_B : INTEGER := 0;
  --ECC Parameters
    C_USE_ECC                   : INTEGER := 0;
    C_USE_SOFTECC               : INTEGER := 0;
    C_HAS_INJECTERR             : INTEGER := 0;
  --Simulation Model Parameters:
    C_SIM_COLLISION_CHECK       : STRING  := "NONE";
    C_COMMON_CLK                : INTEGER := 0;
    C_DISABLE_WARN_BHV_COLL     : INTEGER := 0;
    C_DISABLE_WARN_BHV_RANGE    : INTEGER := 0
  PORT (
  -- Input and Output Declarations
  -- Native BMG Input and Output Port Declarations
  --Port A:
    CLKA                             : IN  STD_LOGIC := '0';
    RSTA                             : IN  STD_LOGIC := '0';
    ENA                              : IN  STD_LOGIC := '0';
    REGCEA                           : IN  STD_LOGIC := '0';
    WEA                              : IN  STD_LOGIC_VECTOR(C_WEA_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
    ADDRA                            : IN  STD_LOGIC_VECTOR(C_ADDRA_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
    DINA                             : IN  STD_LOGIC_VECTOR(C_WRITE_WIDTH_A-1 DOWNTO 0) := (OTHERS => '0');
    DOUTA                            : OUT STD_LOGIC_VECTOR(C_READ_WIDTH_A-1 DOWNTO 0);
  --Port B:
    CLKB                             : IN  STD_LOGIC := '0';
    RSTB                             : IN  STD_LOGIC := '0';
    ENB                              : IN  STD_LOGIC := '0';
    REGCEB                           : IN  STD_LOGIC := '0';
    WEB                              : IN  STD_LOGIC_VECTOR(C_WEB_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
    ADDRB                            : IN  STD_LOGIC_VECTOR(C_ADDRB_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
    DINB                             : IN  STD_LOGIC_VECTOR(C_WRITE_WIDTH_B-1 DOWNTO 0) := (OTHERS => '0');
    DOUTB                            : OUT STD_LOGIC_VECTOR(C_READ_WIDTH_B-1 DOWNTO 0);
  --ECC:
    INJECTSBITERR                    : IN  STD_LOGIC := '0';
    INJECTDBITERR                    : IN  STD_LOGIC := '0';
    SBITERR                          : OUT STD_LOGIC;
    DBITERR                          : OUT STD_LOGIC;
    RDADDRECC                        : OUT STD_LOGIC_VECTOR(C_ADDRB_WIDTH-1 DOWNTO 0);
  -- AXI BMG Input and Output Port Declarations
    -- AXI Global Signals
    S_AClk                         : IN  STD_LOGIC := '0';
    S_ARESETN                      : IN  STD_LOGIC := '0';
    -- AXI Full/Lite Slave Write (write side)
    S_AXI_AWID                     : IN  STD_LOGIC_VECTOR(C_AXI_ID_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
    S_AXI_AWADDR                   : IN  STD_LOGIC_VECTOR(31 DOWNTO 0) := (OTHERS => '0');
    S_AXI_AWLEN                    : IN  STD_LOGIC_VECTOR(7 DOWNTO 0) := (OTHERS => '0');
    S_AXI_AWSIZE                   : IN  STD_LOGIC_VECTOR(2 DOWNTO 0) := (OTHERS => '0');
    S_AXI_AWBURST                  : IN  STD_LOGIC_VECTOR(1 DOWNTO 0) := (OTHERS => '0');
    S_AXI_AWVALID                  : IN  STD_LOGIC := '0';
    S_AXI_AWREADY                  : OUT STD_LOGIC;
    S_AXI_WDATA                    : IN  STD_LOGIC_VECTOR(C_WRITE_WIDTH_A-1 DOWNTO 0) := (OTHERS => '0');
    S_AXI_WSTRB                    : IN  STD_LOGIC_VECTOR(C_WEA_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
    S_AXI_WLAST                    : IN  STD_LOGIC := '0';
    S_AXI_WVALID                   : IN  STD_LOGIC := '0';
    S_AXI_WREADY                   : OUT STD_LOGIC;
    S_AXI_BID                      : OUT  STD_LOGIC_VECTOR(C_AXI_ID_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
    S_AXI_BRESP                    : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
    S_AXI_BVALID                   : OUT STD_LOGIC;
    S_AXI_BREADY                   : IN  STD_LOGIC := '0';
    -- AXI Full/Lite Slave Read (Write side)
    S_AXI_ARID                     : IN  STD_LOGIC_VECTOR(C_AXI_ID_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
    S_AXI_ARADDR                   : IN  STD_LOGIC_VECTOR(31 DOWNTO 0) := (OTHERS => '0');
    S_AXI_ARLEN                    : IN  STD_LOGIC_VECTOR(8-1 DOWNTO 0) := (OTHERS => '0');
    S_AXI_ARSIZE                   : IN  STD_LOGIC_VECTOR(2 DOWNTO 0) := (OTHERS => '0');
    S_AXI_ARBURST                  : IN  STD_LOGIC_VECTOR(1 DOWNTO 0) := (OTHERS => '0');
    S_AXI_ARVALID                  : IN  STD_LOGIC := '0';
    S_AXI_ARREADY                  : OUT STD_LOGIC;
    S_AXI_RID                      : OUT  STD_LOGIC_VECTOR(C_AXI_ID_WIDTH-1 DOWNTO 0) := (OTHERS => '0');
    S_AXI_RDATA                    : OUT STD_LOGIC_VECTOR(C_WRITE_WIDTH_B-1 DOWNTO 0);
    S_AXI_RRESP                    : OUT STD_LOGIC_VECTOR(2-1 DOWNTO 0);
    S_AXI_RLAST                    : OUT STD_LOGIC;
    S_AXI_RVALID                   : OUT STD_LOGIC;
    S_AXI_RREADY                   : IN  STD_LOGIC := '0';
    -- AXI Full/Lite Sideband Signals
    S_AXI_INJECTSBITERR              : IN  STD_LOGIC := '0';
    S_AXI_INJECTDBITERR              : IN  STD_LOGIC := '0';
    S_AXI_SBITERR                    : OUT STD_LOGIC;
    S_AXI_DBITERR                    : OUT STD_LOGIC;
    S_AXI_RDADDRECC                  : OUT STD_LOGIC_VECTOR(C_ADDRB_WIDTH-1 DOWNTO 0)
  END COMPONENT; --blk_mem_gen_v8_3_6
END coregen_comp_defs;
-- axi_lite_if.vhd
-- laws.
-- DISCLAIMER
-- Filename:        axi_lite_if.vhd
-- Description:     Derived AXI-Lite interface module.
-- Structure:
--              axi_bram_ctrl.vhd (v1_03_a)
--                      |-- full_axi.vhd
--                      |   -- sng_port_arb.vhd
--                      |   -- lite_ecc_reg.vhd
--                      |       -- axi_lite_if.vhd
--                      |   -- wr_chnl.vhd
--                      |       -- wrap_brst.vhd
--                      |       -- ua_narrow.vhd
--                      |       -- checkbit_handler.vhd
--                      |           -- xor18.vhd
--                      |           -- parity.vhd
--                      |       -- checkbit_handler_64.vhd
--                      |           -- (same helper components as checkbit_handler)
--                      |       -- parity.vhd
--                      |       -- correct_one_bit.vhd
--                      |       -- correct_one_bit_64.vhd
--                      |   -- rd_chnl.vhd
--                      |           -- xor18.vhd
--                      |           -- parity.vhd
--                      |       -- parity.vhd
--                      |-- axi_lite.vhd
--                      |       -- xor18.vhd
--                      |       -- parity.vhd
-- History:
--      generics:                               "C_*"
library IEEE;
entity axi_lite_if is
  generic (
    -- AXI4-Lite slave generics
    -- C_S_AXI_BASEADDR        : std_logic_vector       := X"FFFF_FFFF";
    -- C_S_AXI_HIGHADDR        : std_logic_vector       := X"0000_0000";
    C_S_AXI_ADDR_WIDTH      : integer                := 32;
    C_S_AXI_DATA_WIDTH      : integer                := 32;
    C_REGADDR_WIDTH         : integer                := 4;    -- Address bits including register offset.
    C_DWIDTH                : integer                := 32);  -- Width of data bus.
  port (
    LMB_Clk : in std_logic;
    LMB_Rst : in std_logic;
    -- AXI4-Lite SLAVE SINGLE INTERFACE
    S_AXI_AWADDR  : in  std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
    S_AXI_AWVALID : in  std_logic;
    S_AXI_AWREADY : out std_logic;
    S_AXI_WDATA   : in  std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
    S_AXI_WSTRB   : in  std_logic_vector((C_S_AXI_DATA_WIDTH/8)-1 downto 0);
    S_AXI_WVALID  : in  std_logic;
    S_AXI_WREADY  : out std_logic;
    S_AXI_BRESP   : out std_logic_vector(1 downto 0);
    S_AXI_BVALID  : out std_logic;
    S_AXI_BREADY  : in  std_logic;
    S_AXI_ARADDR  : in  std_logic_vector(C_S_AXI_ADDR_WIDTH-1 downto 0);
    S_AXI_ARVALID : in  std_logic;
    S_AXI_ARREADY : out std_logic;
    S_AXI_RDATA   : out std_logic_vector(C_S_AXI_DATA_WIDTH-1 downto 0);
    S_AXI_RRESP   : out std_logic_vector(1 downto 0);
    S_AXI_RVALID  : out std_logic;
    S_AXI_RREADY  : in  std_logic;
    -- lmb_bram_if_cntlr signals
    RegWr         : out std_logic;
    RegWrData     : out std_logic_vector(0 to C_DWIDTH - 1);
    RegAddr       : out std_logic_vector(0 to C_REGADDR_WIDTH-1);
    RegRdData     : in  std_logic_vector(0 to C_DWIDTH - 1));
end entity axi_lite_if;
library unisim;
use unisim.vcomponents.all;
architecture IMP of axi_lite_if is
  -- Signal declaration
  signal new_write_access       : std_logic;
  signal new_read_access        : std_logic;
  signal ongoing_write          : std_logic;
  signal ongoing_read           : std_logic;
  signal S_AXI_RVALID_i         : std_logic;
  signal RegRdData_i            : std_logic_vector(C_DWIDTH - 1 downto 0);
  -- Handling the AXI4-Lite bus interface (AR/AW/W)
  -- Detect new transaction.
  -- Only allow one access at a time
  new_write_access  <= not (ongoing_read or ongoing_write) and S_AXI_AWVALID and S_AXI_WVALID;
  new_read_access   <= not (ongoing_read or ongoing_write) and S_AXI_ARVALID and not new_write_access;
  -- Acknowledge new transaction.
  S_AXI_AWREADY <= new_write_access;
  S_AXI_WREADY  <= new_write_access;
  S_AXI_ARREADY <= new_read_access;
  -- Store register address and write data
  Reg: process (LMB_Clk) is
  begin
    if LMB_Clk'event and LMB_Clk = '1' then
      if LMB_Rst = '1' then
        RegAddr   <= (others => '0');
        RegWrData <= (others => '0');
      elsif new_write_access = '1' then
        RegAddr   <= S_AXI_AWADDR(C_REGADDR_WIDTH-1+2 downto 2);
        RegWrData <= S_AXI_WDATA(C_DWIDTH-1 downto 0);
      elsif new_read_access = '1' then
        RegAddr   <= S_AXI_ARADDR(C_REGADDR_WIDTH-1+2 downto 2);
      end if;
    end if;
  end process Reg;
  -- Handle write access.
  WriteAccess: process (LMB_Clk) is
  begin
        ongoing_write <= '0';
        ongoing_write <= '1';
      elsif ongoing_write = '1' and S_AXI_BREADY = '1' then
      end if;
      RegWr <= new_write_access;
    end if;
  end process WriteAccess;
  S_AXI_BVALID <= ongoing_write;
  S_AXI_BRESP  <= (others => '0');
  -- Handle read access
  ReadAccess: process (LMB_Clk) is
  begin
        ongoing_read   <= '0';
        S_AXI_RVALID_i <= '0';
        ongoing_read   <= '1';
      elsif ongoing_read = '1' then
        if S_AXI_RREADY = '1' and S_AXI_RVALID_i = '1' then
        else
          S_AXI_RVALID_i <= '1'; -- Asserted one cycle after ongoing_read to match S_AXI_RDDATA
        end if;
      end if;
    end if;
  end process ReadAccess;
  S_AXI_RVALID <= S_AXI_RVALID_i;
  S_AXI_RRESP  <= (others => '0');
  Not_All_Bits_Are_Used: if (C_DWIDTH < C_S_AXI_DATA_WIDTH) generate
  begin
    S_AXI_RDATA(C_S_AXI_DATA_WIDTH-1 downto C_S_AXI_DATA_WIDTH - C_DWIDTH)  <= (others=>'0');
  end generate Not_All_Bits_Are_Used;
  RegRdData_i <= RegRdData;             -- Swap to - downto
  S_AXI_RDATA_DFF : for I in C_DWIDTH - 1 downto 0 generate
  begin
    S_AXI_RDATA_FDRE : FDRE
      port map (
        Q  => S_AXI_RDATA(I),
        C  => LMB_Clk,
        CE => ongoing_read,
        D  => RegRdData_i(I),
        R  => LMB_Rst);
  end generate S_AXI_RDATA_DFF;
-- laws.
-- DISCLAIMER
-- Filename:        checkbit_handler_64.vhd
-- Description:     Generates the ECC checkbits for the input vector of
--                  64-bit data widths.
-- VHDL-Standard:   VHDL'93/02
-- Structure:
--                      |-- full_axi.vhd
--                      |   -- wr_chnl.vhd
--                      |           -- xor18.vhd
--                      |           -- parity.vhd
--                      |       -- parity.vhd
--                      |   -- rd_chnl.vhd
--                      |           -- xor18.vhd
--                      |           -- parity.vhd
--                      |       -- parity.vhd
--                      |-- axi_lite.vhd
--                      |       -- xor18.vhd
--                      |       -- parity.vhd
-- History:
-- JLJ      2/2/2011         v1.03a
--      generics:                               "C_*"
library IEEE;
entity checkbit_handler_64 is
  generic (
    C_ENCODE   : boolean := true;
    C_REG      : boolean := false;
    C_USE_LUT6 : boolean := true);
  port (
    Clk             : in    std_logic;
    DataIn          : in  std_logic_vector (63 downto 0);
    CheckIn         : in  std_logic_vector (7 downto 0);
    CheckOut        : out std_logic_vector (7 downto 0);
    Syndrome        : out std_logic_vector (7 downto 0);
    Syndrome_7      : out std_logic_vector (11 downto 0);
    Syndrome_Chk    : in  std_logic_vector (0 to 7);
    Enable_ECC : in  std_logic;
    UE_Q       : in  std_logic;
    CE_Q       : in  std_logic;
    UE         : out std_logic;
    CE         : out std_logic
end entity checkbit_handler_64;
library unisim;
-- library axi_bram_ctrl_v1_02_a;
-- use axi_bram_ctrl_v1_02_a.all;
architecture IMP of checkbit_handler_64 is
  component XOR18 is
    generic (
      C_USE_LUT6 : boolean);
    port (
      InA : in  std_logic_vector(0 to 17);
      res : out std_logic);
  end component XOR18;
  component Parity is
    generic (
      C_USE_LUT6 : boolean;
      C_SIZE     : integer);
    port (
      InA : in  std_logic_vector(0 to C_SIZE - 1);
      Res : out std_logic);
  end component Parity;
 --    component ParityEnable
 --      generic (
 --        C_USE_LUT6 : boolean;
 --        C_SIZE     : integer);
 --      port (
 --        InA    : in  std_logic_vector(0 to C_SIZE - 1);
 --        Enable : in  std_logic;
 --        Res    : out std_logic);
 --    end component ParityEnable;
  signal data_chk0          : std_logic_vector(0 to 34);
  signal data_chk1          : std_logic_vector(0 to 34);
  signal data_chk2          : std_logic_vector(0 to 34);
  signal data_chk3          : std_logic_vector(0 to 30);
  signal data_chk4          : std_logic_vector(0 to 30);
  signal data_chk5          : std_logic_vector(0 to 30);
  signal data_chk6          : std_logic_vector(0 to 6);
  signal data_chk6_xor      : std_logic;
  -- signal data_chk7_a        : std_logic_vector(0 to 17);
  -- signal data_chk7_b        : std_logic_vector(0 to 17);
  -- signal data_chk7_i        : std_logic;
  -- signal data_chk7_xor      : std_logic;
  -- signal data_chk7_i_xor    : std_logic;
  -- signal data_chk7_a_xor      : std_logic;
  -- signal data_chk7_b_xor    : std_logic;
    -- Add bits for 64-bit ECC
    -- 0 <= 0 1 3 4 6 8 10 11 13 17 19 21 23 25 26 28 30
    --      32 34 36 38 40 42 44 46 48 50 52 54 56 57 59 61 63
  data_chk0 <= DataIn(0) & DataIn(1) & DataIn(3) & DataIn(4) & DataIn(6) & DataIn(8) & DataIn(10) &
               DataIn(11) & DataIn(13) & DataIn(15) & DataIn(17) & DataIn(19) & DataIn(21) &
               DataIn(23) & DataIn(25) & DataIn(26) & DataIn(28) & DataIn(30) &
               DataIn(32) & DataIn(34) & DataIn(36) & DataIn(38) &
Posting that much code in a syntax window is ridiculous nobody is going to want to scroll through 1631 lines of code to look for one signal, that is not even in the posted code (I had to copy the code to a text editor). If you have this much code to post zip the code and add it as an edaboard attachment.
Im really not sure what you're expecting us to do. That is a lot of code. Maybe we could help if you actually created a small example showing the problem.
Otherwise this is your job - debug your code and find the problem.
ok, the root cause is that Xilinx AXI BRAM slave IP does not support full duplex (simultaneous read and write operations).
I have already made a working example using other AXI slave code.
I will make the AXI example available soon here.
See this AXI demo example
The AXI slave is from other people.
I will replace the AXI slave code with my own and formally verify the entire AXi transactions when I have time later.
Now, I am adding NACK handling feature (axi_bresp returns failure status) to AXI master code
However, I am not sure how to handle AXI_AWVALID signal during NACK handling procedure.
Please advise.
If you have already asserted AWVALID, then it, and all other AW*** signals must remain stable until AWREADY is asserted.
Other than that, thats a design decision.
However, AWVALID and AWADDR (clocked-reg signal) can only be determined after BRESP and BVALID signal are returned from AXI slave.
In the case of re-transmitting burst for NACK handling, there is always possibility of wasting a write burst due to wrong prediction of BRESP.
I would suggest that waiting for bresp makes for an innefficient mememory interface. If you're talking to DDR you could be waiting a long time for a sent write to actually complete, espeically if it has internal buffering and mutliple interfaces. Usually its best just to throw as much data at is as possible, and do retries later.
Are you suggesting out-of-order transaction where AXI master does not wait for BRESP from AXI slave ?
There is nothing out of order about it.
For each AWADDR, there is a WDATA from the master, sometime later, there is a BRESP. You can send as many pairs of AWADDR and WDATA as the slave will accept without any BRESP appearing yet. As long as the order corresponds, everything is in order.
Out of order would allow AWADDR and WDATA to not correspond (using different AWIDs and WIDs). This is this is allowed in AXI3, but not AXI4 (Note there is no WID channel in AXI4).
Waiting for BRESP simply wasts potential time on the interface. Imagine some high speed interface (say 25G ethernet). Waiting a couple hundred clocks for a BRESP could lose you a few packets.
