AWR desing environment tutorial
awr s parameters example
useful!
Added after 6 minutes:
useful
Reactions: thanhtuph
    V
    thanhtuph
awr example wizard
good tutorial
    V
awr microwave office video lessons
i need the tutorial pls...
Added after 2 minutes:
quick reference
    V
    thanhtuph
kikkert awr
Does anyone in here can help me get started with the simulation for a bjt frequency multiplier on AWR?
    V
tutorial awr design environment
check Maas book , nonlinear RF and microwave circuits
it will help u
khouly
    V
mwo userguide
Thank you!
    V
mwo projects.pdf
thank you for all, it is a great help to get started in this software
amplifier awr tutorial
Hello All AWR MWO Users,
I have collected list of documents / articles on different RF/Microwave design using
AWR Microwave Office (MWO), if any one interested they can use this links to download the documents...
Even though if you google on the interent you will get this but most of the time it is difficult to sort &
filter the required documents...Hence I am placing at one place , these are working ones as on 17th of April 2008...
http://www.gigacomp.ch/pdfs/AWR_Tutorial.pdf
http://www.rfcircuitdesign.com/AMPCAS1.PDF
http://www.astro.umd.edu/~harris/docs/w3summary.pdf
http://www.analog.com/UploadedFiles/Application_Notes/40203204AN764_0.pdf
http://ir.canterbury.ac.nz/bitstream/10092/164/1/12602629_Main.pdf
http://www.highfrequencyelectronics.com/Archives/Mar04/HFE0304_Imparato.pdf
http://www.urel.feec.vutbr.cz/~raida/multimedia_en/chapter-4/4_5A.pdf
http://www.highfrequencyelectronics.com/Archives/May06/HFE0506_Cree.pdf
http://www.hamsdr.com/data/GlobalFileUploads/13__VHF_SiC_amplifier_by_N2UO.pdf
I hope this helps most of AWR MWO users...If some one has articles or links other listed here do post here...
---manju---
awr mwo script examples
Thank you very much for providing so many good documents for learning Microwave Office!
Added after 3 minutes:
Hello, is there any other documents focusing on dipole & monopole antenna design? Thanks
awr mwo tutotial
Which one is better for the simulation ?
Microwave Office & ADS
awr microwave office tutorials
Hello kwokhinglai,
First of all you need to your requirements ...
1. what type of design your are doing (linear or Nonlinear)?
2. Is your implimentation is MIC/MMIC/LTCC or etc? then whether the foundry kit available?
3. Interface to 3rd party tools for accurate analysis & for complete design flow?
4. what is the schedule for the design & development?
5. Finally budget available for the product purchase...?
I think when you put all together you will find AWR Microwave Office is best choice for most of the applications ...As Agilent ADS lacks Layout features, ease of use & some advanced automation tools...
---manju---
sir help is required for finding ..tutorial for millimeter wave detector in microwave office
thanks
    V
Hi Everyone
Im looking for tutorial to Design Filter (Tchebychev Filter , Passband-- 5.7 GHz-5-8 GHz)in the microstrip R04003 C ...
Thanks
joe
hi...
is there know tutorial about Defected Ground Structure Tutorial using AWR simulator???
thank..:D
HI
Are there any tutorial in design LNA using AWR software. I need to design LNA in frequency range 3.3-3.8GHz using AWR software.
Ur help are much appreciated,
Thanks.
hi.
I m a New user of AWR..
I request if you have any tutorial over filter design or coupled suspended stripline, then please give..
Thanks..
