Shayaan_Mustafa
Full Member level 5
By the way , think on this issue , until i come back : why the voltage across the out put inductor is AC ? an AC square wave !!!!! . try to find a reason for it .
I thought about it. And I am confused. Inductor blocks AC. Right?
I have some question sir;
1) We have made Buck regulator. Why can't we use linear voltage regulators?
2) And when I was searching for this Buck regulator (Switched mode converter). I found that it was under the section of DC to DC converters. What is this? Will you please help me out of this?
3) What is free-wheeling operation? What is free-wheeling diode?
4) Capacitors for switched regulators are chosen on the basis of effective series resistance (ESR).
I found this statement in the link which I provided you in the post#438. So will you please elaborate this? I have never heard about ESR.
5) Most of the switched supplies needs a minimum load, in order to ensure that the inductor carries current always. If the current flow through the inductor is not continuous, regulation may become poorer.
Why is it necessary for current to be continuous? I also found this statement on the given link.
