ARM7 Philips LPC2000 Debugger Schematics with Keil?
wiggler + keil
SPATAN said:
eng_ahmed22 said:
Kolia said:
SphinX said:
Salam,
I search schematics for LPC2000 ARM Debugger compatible with Keil uVision3, A
ULINK shematics and PCB <:D>
Hi
many thanks Kolia for the schematic :)
but the code for the AN2131Q is missing??
where can i find it???
or it is not important ????
many thanks
Ahmed
AN2131Q not use code. It read only VID/PID from eeprom.
sorry for the same query again...... Do you mean, blank controller (AN2131Q) works here....
Also they are absoluting AN2131Q (not recommended for new designs), so we ve to replace it with CY7C64713.
lpc2000 flash programmer circuit
not blank... software is downloaded to AN2131QC via usb
i think u should ask cypress if software compiled for AN2131 (in binary format) will work correctly with CY7C64713...
or i think somebody could take schematic and parts from ulink2... and post it here... it would be great :)
lpc 2xxx debugger
I made a ULINK successfully,it works with Keil RVMDK perfectly
keil ulink-me schematic
From where did you get the AN2131QC? I thought it is obsoleted... Can you help me get one?
phılıps shematics
resistor R3 open in pdf.
