ARES (PCB design) LCD connection
I can't understand what is happening, I have never seen the zone created by default, I have always added the zone manually.
Maybe you have checked an option in the project settings.
Are you able to remove it and it comes back?
Have you tried in an empty ARES project to add and remove the zone, is the behavior in the pic project different from that?
Also draw a simple circuit with a couple of components in ISIS and create a PCB fr it, do you get the zone?
Alex
Hey can you please tell me how you got this PCB schematic for LCD .
Which LCD you used in proteus.
Actually I'm working on LCD in proteus and it has a schematic which shows 7-pins on each side, but i want 14 pin single line pcb, as you used.
Please tell me how you got this .
Thanx
---------- Post added at 17:07 ---------- Previous post was at 16:50 ----------
CAn anyone tell me, How to get the Pcb layout of LCD, as you used in the picture.
Mean to say that 14 pin one line layout.
I'm getting 7-pin two line layout.
Please help me . . .
in isis right click your lcd component and select packaging tool , then in the dialog click add to add a package and select the package you want, the pins should be assigned automatically in the numbers, then save the component to a new lib and use it from there
Alex
